3.8 supercharged in a foxbody ? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 09-12-2007, 08:59 PM Thread Starter
I have a 89 lx hatch that has a blown out tranny, and about 200,000 on the engine so its time for a change.
i also have 8 3.8 super charged engine,5spd, tranny, wiring and ecu. That i thought would be good to shove in the fox body if its possable.
has anyone ever done this or even know if its remotely possably. If someone has id like to know what needs to be done to make it happen.
thanks Mike
stang_crazy is offline
post #2 of 8 Old 09-12-2007, 09:46 PM
www.v6power.net
Or the Six Cylinder forum on this site if you don't already have a duplicate post there.
mfpmax is offline
post #3 of 8 Old 09-13-2007, 04:47 PM
the 5 speed, if it is out of an sc wont do you good, you'll need a t5 to go with that 3.8. it most certainly can be done. you'll need the eec, and the entire harness from the supercoupe.
sinhumane is offline
post #4 of 8 Old 09-13-2007, 07:59 PM Thread Starter
well the 5spd is from a 90 cougar, but i assume its the same. So basicly a t-5 from a 5.0 stang should do the trick. My main thing is doing the wiring as far as ignition, fuel pump ect...
what i can get rid of on the sc engine as far as emissions crap blah blah.
any help would be greatly appreciated.
Also i must ask hows come the 5spd wont work from the SC?
post #5 of 8 Old 09-13-2007, 09:46 PM
The shifter is in a different position than the T5.
mfpmax is offline
post #6 of 8 Old 09-13-2007, 10:42 PM Thread Starter
thanks. also if i wanted to stick with an auto tranny what would be a good one to use? will a 4R70W bolt up to it or no?
post #7 of 8 Old 09-15-2007, 10:18 AM
Trader Feedback: (37)
3800 sc
Helm Publications of detroit does wiring prints for Ford ..I got a print for the wiring in a 90 sc so I could use the motor in a 29 Model A..was 12.00 at that time ...I dont have the number to call and order but the address is...Helm Incorporated...PO box 87150....Detroit Michagain ....48207 ...hope this will help some
joseph4594 is offline
post #8 of 8 Old 09-16-2007, 12:39 AM Thread Starter
kool, I can get any wiring diagram i need at work with all data. Its just gonna take time just like the rest of the projects i got goin.
