98 odometer quit help!!!!!!!! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 08-18-2007, 10:56 PM Thread Starter
ledfootky's Avatar
Exclamation 98 odometer quit help!!!!!!!!
my friend has a 98 stang and his odometer quit working are they electric or cable his speedo still works though he says?
331stroker, 9 to 1 comp ratio,ross inverted pistons,eagle crank & rods,1.7 roller rockers, oversized valves,roush 200 series fully ported heads,75 pro-m,65 tb, 30# injectors,edelbrock performer rpm 2 intake,tko 600,alum driveshaft,upper lower control arms,tub k-member & a-arms,pre93 comp
ledfootky is offline
post #2 of 4 Old 08-20-2007, 04:57 PM Thread Starter
ledfootky's Avatar
bump
post #3 of 4 Old 08-28-2007, 02:14 AM
there is a how to at 3.8mustang
DIY: Repair your broken Odometer & Tripometer
I couldn't post the URL
GtrTech is offline
post #4 of 4 Old 09-10-2007, 08:51 PM
easy peasy. this is why you dont reset the trip odometer with the car moving. the odometer gear stripped out on you. its a little 20-tooth gear in your cluster. yours is analog. not a digi display, right?
sinhumane is offline
