Quick question for you sixers - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 07-28-2007, 10:55 AM Thread Starter
Will the sc from a supercoupe work on a 02 3.8? Just wondering what would be involved with doing this if it is at all possible.
Thanks,
Chris
2000 Mustang GT- Gears, X-pipe, catback, pullies, DRs.
[email protected] 1.85 60ft.
2kMustangGT500 is offline
post #2 of 7 Old 07-28-2007, 04:16 PM
Well the 99+ 3.8, ALL 4.2's, and the (I think) 96+ windstars are what they call "Split-Port" induction. Which means they have 2 intake ports instead of one. The older 3.8's are single-port, meaning, obviously, that there is only 1 intake port/cylinder. All supercoupe's were single-port. So the SC intake would not fit the split-port heads. If you were to make a custom intake manifold then this would be possible, but certainly not cost effective. You could also convert the car BACK to the single-port heads so you could use the SC intake, but this would be a step backwards in technology. The split-port engines have 190hp so you'd almost be better off just putting a 4.2L shortblock underneath it and gaining the same amount of power.
-Thomas
Thomas is offline
post #3 of 7 Old 07-28-2007, 05:41 PM
This gets asked quite often at 3.8mustang.com . The general consensus always seemed to be not worth it because of all the fabrications you have to make.
Cougarstang is offline
post #4 of 7 Old 07-30-2007, 04:45 PM
you need to go back to single port, however on that note, some ported single port heads are the best flowing head s on the market, but by the time you spend on all that it will be better jsut to buy a procharger, supposedly SSM is coming out with a kit to put a m112 off a cobra on it, but that was supposed to be out "this summer" like 3 years ago so who knows
09 f-350 lariat CCSB 5.4 - DD
04 f-350 RCLB 6.0 - sold
mustangman022232 is offline
post #5 of 7 Old 08-05-2007, 04:30 PM
Please don't talk about things of which you know nothing about.
It was "speedkillz" that tried to come out with a M112 kit but in the end failed to deliver a product. SSM is comming out with a kit as not only have I seen the production intake, I am running their prototype one.
1995 Mustang GT: Mostly stock
1998 BAB Cobra: Built motor & suspension work
mysteed is offline
post #6 of 7 Old 08-12-2007, 09:39 AM
homank76's Avatar
So how much power you making with this prototype?
homank76 is offline
post #7 of 7 Old 08-12-2007, 08:21 PM
Not enough to catch you Keith.
Not enough...yet.
mysteed is offline
