94 V6 won't start - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 1 Old 07-22-2007, 11:10 PM Thread Starter
S351R"Animal"'s Avatar
94 V6 won't start
I just bought a 94 V6 car that won't start. It turns over and has weak spark, has fuel, but, never actually fires off. The previous owner replaced the heads and when he put it back together this problem started. The coil, crank sensor, plugs, wires have all been replaced. The firing order is correct also. What else is in the system that could be wrong. I don't think he messed with the cam sensor. What else would cause weak spark? I also tried to pull codes using an OBD II scanner and couldn't find any other than the one that says it hasn't been driven enough.
96-13 S351, 99-46 S351, 99-42 S-351, 97-23 S351, 95-43 S351, 96-388 S281, 00-417 S281
S351R"Animal" is offline
