Reasonably priced cat back exh for 99-3.8L - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 11 Old 06-17-2007, 12:50 PM Thread Starter
Any suggestions on who makes a reasonably priced cat back system for the 3.8l v-6?
My motor is bone stock and I dont think I can bear the wimpy exhaust note any longer. Also, can I expect better torque or power from cat back alone? I dont want to go the header route as Ill only have the car for another year or so.
Its a daily driver with the usual power steering whine-is there any way to loose that sound too?
Steve
Steveko is offline
post #2 of 11 Old 06-17-2007, 02:37 PM
You won't notice the power increase from 104rwhp to 107rwhp. I'd save my money
306, TFS heads, Victor EFI, XE282, Tremec, 10" tires, and NX nozzle
99GTC is offline
post #3 of 11 Old 06-17-2007, 03:32 PM
2k2GT's Avatar
I'm not sure if this section is the best to ask for V6 exhaust advice.
2k2GT is offline
post #4 of 11 Old 06-17-2007, 03:47 PM
MFE
Super Moderator
MFE's Avatar
Best thing you can do for a 3.8 is keep it quiet.
MFE is offline
post #5 of 11 Old 06-18-2007, 03:47 PM
Corral Day Kittah
KC LX's Avatar
It started in the Road Race/Autox forum and was moved here.
KC LX is offline
post #6 of 11 Old 06-18-2007, 03:58 PM
MFE
Super Moderator
MFE's Avatar
Winner of the "no #### sherlock" ad for today. it was moved AFTER he posted.
MFE is offline
post #7 of 11 Old 06-18-2007, 06:37 PM
Corral Day Kittah
KC LX's Avatar
Thanks, Dick Tracy, but to those in the 6 cyl forum, it looks like he posted it here first.
KC LX is offline
post #8 of 11 Old 06-18-2007, 07:01 PM
2k2GT's Avatar
I appologize for all the damage and emotional stress i've bestowed upon the Corral.
2k2GT is offline
post #9 of 11 Old 06-19-2007, 04:26 PM
GT take off exhaust with force pro series mufflers from jegs welded in
http://www.dropshots.com/spencer88
if you can afford it, long tubes, with 2.5" O/R H pipe, dual forces again
09 f-350 lariat CCSB 5.4 - DD
04 f-350 RCLB 6.0 - sold
mustangman022232 is offline
post #10 of 11 Old 07-01-2007, 08:10 PM
I have takeoff exhaust from a GT with a custom h-pipe on mine and love it. I'd recommend going that route, as it sounds good and was cheap enough.
Cougarstang is offline
post #11 of 11 Old 07-01-2007, 08:12 PM
104rwhp? I think you overestimate parasitic loss. You might be thinking of the 94-98 sixers. His 99 is starting at 190 crank hp, and is probably seeing in the 150's at the rear wheels
