So I dyno'd my 95... - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 06-17-2007, 10:57 AM Thread Starter
It made a whopping 125.59 rwhp and 187 lb ft. It is the strangest dyno curve I have ever seen. The HP curve is almost linear but the torque curve starts high, peaking at 3,000 rpms, and slowly drops off.
GeorgeD is offline
post #2 of 10 Old 06-17-2007, 07:06 PM
is this bone stock?
bmatyeah is offline
post #3 of 10 Old 06-17-2007, 09:14 PM
kd7cwg's Avatar
Is it an auto?
2001 POS Focus
2002 Crown Vic LX Sport
1997 Suburban K2500
1988 Blue Bird All American
kd7cwg is offline
post #4 of 10 Old 06-18-2007, 06:08 PM
Interesting. I always wondered what one would make. I'm also assuming stock.
tealpony is offline
post #5 of 10 Old 06-19-2007, 04:23 PM
do you have a sheet?
09 f-350 lariat CCSB 5.4 - DD
04 f-350 RCLB 6.0 - sold
mustangman022232 is offline
post #6 of 10 Old 06-19-2007, 10:51 PM Thread Starter
Its a 5-spd and about 98.2% stock. It has a Bassani cat-back, otherwise stock with 133,000 miles. I'll ty to scan in the graph.
GeorgeD is offline
post #7 of 10 Old 07-10-2007, 03:08 PM
thats just the way the 3.8s are , its normal , get a K&N filter , underdrive pulleys and a better flowing midpipe and you should be up in the 135-145 rwhp range pretty quickly .....get a chip for it and it should push you over 150rwhp .....My cousin has a 98 model that we have been working on that started out running 10.8 at 65mph in the eighth stock , that has now run a best of 10.1 on a 2.4 60ft at 72mph from K&N, gutting 2 of the 4 converters , flowmaster catback , underdrive pulleys , and a tune on it .....its getting ready for a supercoupe supercharger on it .....
93GRNLXNVA is offline
post #8 of 10 Old 07-10-2007, 10:56 PM
Sounds about right. The guys at 3.8mustang always said the single ports dyno in the 120's with the stick, and 110's with auto.
UD pullies are your friend. Cheap and effective bolt on
Cougarstang is offline
post #9 of 10 Old 07-30-2007, 08:33 PM
thanks for the stock dyno i just did mine and did 227 whp and 279tq on a mustang dyno .dyno jet would have been around 250 and 303 .what was yours dynod on ?
96b.boy is offline
post #10 of 10 Old 08-05-2007, 04:20 PM
That's not bad for just a catback.
1995 Mustang GT: Mostly stock
1998 BAB Cobra: Built motor & suspension work
mysteed is offline
