94 V6 electrical issues - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 06-12-2007, 10:54 PM Thread Starter
My CD player was stolen a few months ago and I finally decided to replace it with another Kenwood. After I took the stock tape player out, I lost my interior lights, door locks, and power to the stereo. I don't think it's related, but my speedometer is no longer working either.
I'm thinking that all this is too much of a coincidence and that I had to have done something when I was taking the stock player out. I have checked the fuses under the hood and all of them are fine. I've also switched (but not replaced) both relays and that hasn't helped either. There are two empty relay slots and a couple of empty fuse slots, but everything was functioning fine before I did this so I don't think extra slots are the problem.
Can anyone give me any ideas?
92GreenMonster is offline
post #2 of 4 Old 05-05-2009, 05:07 PM
Weaponrider87's Avatar
I heard of something like this before. check to make sure that the illumination wire for the stero isnt bare and shorting out somewhere.
2002 Mustang GT N/A 3.73 Richmond Gears, Auburn Pro Series Diff, Moser 31 Spline Axles, TKO 600, On3Performance 67mm Ball Bearing Turbo Kit.
Weaponrider87 is offline
post #3 of 4 Old 05-05-2009, 05:39 PM
Have you checked the fuses under the dash?
http://z.about.com/d/autorepair/1/0/Q/K/41874387.gif
Specifically, number 8?
No.. I'm not "Fast."
Originally Posted by fkurls1 View Post
Simply awesome! Its like you came down from forum mountain with two stone tablets...
Fast94CobraSVT is offline
post #4 of 4 Old 05-11-2009, 12:26 PM
Trader Feedback: (59)
its a fuse under your dash, a fuse under the dash gives power to everything that youve lost. check it
prddad1 is offline
