fairmont - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 03-10-2007, 12:36 AM Thread Starter
shopny9350's Avatar
fairmont
thoughts and comments
am wanting to build a fairmont futura. everybody does the v-8 swap so why not be diff and maybe put a 3.8 v6 with maybe a turbo in it ? think it would work would motor mounts be a lot different. do they make turbos for 3.8
not looking for a super fast car just sold one of those wanting something different and reliable, little power enuff to be FUN but something can drive anywhere with no hassels have air power all the features
let me hear your thoughts
PROJECT BULLETT FAIRMONT
shopny9350 is offline
post #2 of 5 Old 03-10-2007, 07:59 AM
talk to andy at tmaturbo.com for a twin turbo kit, if you want to know about boost talk to justin at vmptuning.com (they also have procharger kits), he has a twin turbod junk yard 3.8 100% stock tht is running 17psi and high 10s
you can start with a 01-04 2.8 (even stronger blocks) or a 98+ f150 4.2, which is just a longer stroke, ford loosly copyed buicks 231 GN motor, but used an on center block to its a bit stronger and based the heads off the cleavlands, so stock split port (99-04) will put any E7, windsor, or 281 heads to shame
http://3.8mustang.com/forum/showthread.php?t=181471
http://3.8mustang.com/forum/showthread.php?t=113280
http://www.babcox.com/editorial/ar/ar90134.htm
http://www.supersixmotorsports.com/
http://tmaturbo.com/
http://www.vmptuning.com/store/index.php?
what tranny you going to run? something fun for DD you could put in a 4R70W with a stall and shift kit and will last and take a beating, or, if you want a racer you could always put a C4 in
09 f-350 lariat CCSB 5.4 - DD
04 f-350 RCLB 6.0 - sold
mustangman022232 is offline
post #3 of 5 Old 03-10-2007, 08:34 PM Thread Starter
shopny9350's Avatar
cool thanks
just wanting something different
post #4 of 5 Old 03-11-2007, 09:55 PM
sweet keep us informed, the 3.8 is one of fords best kept secrets for greatest motors
post #5 of 5 Old 03-26-2007, 12:11 PM
Sounds like a perfect sleeper. I'd put some grandpa wheels and some quiet mufflers on it so no one would suspect it.
Roger Hams is offline
