Mustang V6 T5 Trans ... - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 03-01-2007, 11:03 AM Thread Starter
Is the Mustang V6 T5 transmission the same from '94 thru 2004? Not concerned about details (gear ratios, external switches, etc.), just if it they will physically interchange between '94 & '04 w/no driveshaft, shifter or bell housing alterations.
'98 GT equipped w/Koni, Eibach, Cobra R rims w/Yokohama tires, Cobra brakes all around & 3.73 gears. Also a Boss330 4.6 Cobra block w/PI heads & stuff from Accufab, ARP, Centerforce, Comp Cams, Fidanza, K&N, Mahle, Manley & Borla exhaust w/Mac Pro Chamber thrown in for grins & giggles.
Geezer is offline
post #2 of 5 Old 03-03-2007, 09:04 PM
yes
09 f-350 lariat CCSB 5.4 - DD
04 f-350 RCLB 6.0 - sold
mustangman022232 is offline
post #3 of 5 Old 03-05-2007, 02:15 PM Thread Starter
Mustang V6 T-5 Trans
THANK YOU!!!
Geezer is offline
post #4 of 5 Old 03-11-2007, 06:20 PM
for some reason i wana say the 99+ is an electronic speed sencor and not the mechanical such as the pre 99 trannys
ProCharged Splitport Powered 1995 v6
95sn95 is offline
post #5 of 5 Old 03-11-2007, 09:56 PM
you would be correct
