swap for v6 auto - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 02-24-2007, 03:53 AM Thread Starter
swap for v6 auto
What is the best engine to swap into my 98 v6 automatic and what all will need to be done for the engine to fit?
goodfellas98 is offline
post #2 of 6 Old 03-01-2007, 11:05 AM
"best" is all relative for what you want to do, like low end torque for the street or big turbo setup for top, low compression for a power adder end ect. After you decide what you need from the motor, then you can decide on what to get and how to fit it.
BootlegGT is offline
post #3 of 6 Old 03-03-2007, 09:08 PM
either a tbird supercoupe 3.8 with an eaton on top, you need dual exhaust though, or, a ford f150 4.2 V6, you will have to reuse your stock 3.8 upper intake manifold though
09 f-350 lariat CCSB 5.4 - DD
04 f-350 RCLB 6.0 - sold
mustangman022232 is offline
post #4 of 6 Old 03-14-2007, 12:42 PM
Will a 91 supercharged T-bird motor bolt right into a 97 V6 mustang? Will I need to do anything else to get everything to work?
Thanks, I am new to the V6 mustang world.
PearlPony is offline
post #5 of 6 Old 03-14-2007, 06:50 PM
rpm-mustangs . com sells engines that may be worth lookin at. They have 3.8s and 4.2 strokers with or without forged internals. If i were going to turn my sixxer into a big project, i would probably start here.
trock is offline
post #6 of 6 Old 03-14-2007, 09:33 PM
it will need to be tuned, might need the computer, and just very small things will be needed, but yes, its a easier swap then a 4.6/5.0 swap
