pinging noise after shutdown - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 01-11-2007, 07:11 PM Thread Starter
Whenever I switch the car off I here this like tapping or pinging noise from the motor? Check engine light is on and the code is P0171 which means system too lean on bank one. Are the two things related? Where should I start to diagnose? The guy at Advance said to check the PCV tube that it might be sucking air. Any help is appreciated. TIA
Billy
supu80 is offline
post #2 of 2 Old 01-18-2007, 01:27 PM
MYLITTLEHO's Avatar
the tapping noise could be coming from the catalytic converter.. if the engine runs leans it will burn out the Catalytic converter pretty quick.. or a broken/plugged cat could be causing your lean condition
Best E.T to date 14.02 @ 98.7
MYLITTLEHO is offline
