EGR help please - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 12-31-2006, 12:27 PM Thread Starter
EGR help please
I just got my car back from having two blown heads replaced. Check engine comes on and the code is P1407. It means no flow of EGR I understand. Its a 95 v6. i checked the hoses and electrical connections for voltage. i followed the procedures in my haynes manual and if u have one i did whats on page 6-18 and 6-19. in section 5 i did line 9, 15, 16, and 17. all checked out ok. the 18th line i couldnt quite figure out what they were saying. anyway, i need to know if the lines are hooked up correctly to start with that may be the problem. there is the pipe from the exhaust manifold to the egr valve. the first hose from the botton of that pipe goes to the backside of the DPFE sensor, the side opposite of the electrical connection. the next hose up goes to the front side of the same sensor on the same side as the connection. also from the manifold vacumm port there is a red hose that goes to the bottom port of the EVR, and from the EGR valve there is a green hose that goes to the top port of the EVR. are the hoses in the correct sequence? TIA
Billy
supu80 is offline
post #2 of 2 Old 01-05-2007, 10:59 PM
plstktnkr2's Avatar
did ya check your idle air control motor maybe is gunked shut?
'66 lincoln ragtop,
1983 Mustang convertable S/C V6
1985 Lincoln Town Car Hearse
Four-Eyed pony posse member
plstktnkr2 is offline
