94 V6 blown head gasket - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 12-15-2006, 05:30 PM Thread Starter
Trader Feedback: (-1)
I may be replacing a pair of head gaskets on a 94 V6 car. It kinda seems like this is something Ford had a problem with??? Has anyone replaced theirs? Did the short block survive and how much would the average shop charge?
shmokinjoe is offline
post #2 of 5 Old 12-15-2006, 06:30 PM
its a very common problem on 94-mid 96s
get the heads milled and checked for warpage, get 99+ MLS head gaskets from rpm-mustangs.com and ARP bolts and studs
09 f-350 lariat CCSB 5.4 - DD
04 f-350 RCLB 6.0 - sold
mustangman022232 is offline
post #3 of 5 Old 12-17-2006, 10:17 PM
cobraman1024's Avatar
Trader Feedback: (69)
shops charge a minimum of $900; i paid $1050 to get mine done. that was at about 107,000 miles. now the car is at 157,000 and we're doing a split-port swap from an 01 v6. when i had the gasket job done 5 of 6 cylinder gasket sections were blown and my shortblock survived 3000 miles with the engine this way prior to the repair.
-1995 Cobra #182/4005; 305hp/ 300tq, 231k miles, Roush intake, export parts
-1996 Mystic Cobra #1666/2000; 351hp/309tq, 221k miles, built 284, H/C/I, ARH, Mezeire, LMAF, JLT, MM suspension
-1993 Mustang LX, 2.3L w/ T5 conversion, AJE/MM suspension w/ 8.8, 03 Cobra steering/brakes, 271k miles
cobraman1024 is offline
post #4 of 5 Old 12-17-2006, 11:45 PM
gsagriff's Avatar
Same thing happened to me. My car was peeing coolant out of my exhaust pipes. I junked the motor. Then, I did a v8 swap..
Swapped '95 Stang
Swapped to 5.0 V8, Shaved Everything, American Thunder Flowmaster Exhaust, King Cobra Clutch, Fox Body Throttle Body and Intake, BBK Shorty Headers, BBK Off Road H-Pipe, Fluidyne Aluminum Radiator
gsagriff is offline
post #5 of 5 Old 12-19-2006, 09:21 PM
it might be cheaper to just get a newer motor, mpsautosalvage.com has used 3.8s, a 97 is pretty much a direct bolt in, a 99 would be a decent swap, or what i would do, is find one out of a thunderbird supercoupe, then you go from a high 16 second car to a high 13 second car
