2000 must. V6 into 94 v6 must. - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 10-26-2006, 09:18 PM Thread Starter
Does anybody know if it is possible or even worthwhile to put a 2000 mustang 3.8 splitport and auto trans into a 94 mustang that has the old style 3.8 and auto trans.? I have both complete cars but I don't want to change the wires under the dash. Are the transmissions the same? Any info would be greatly appreciated.
lx351 is offline
post #2 of 9 Old 10-28-2006, 01:09 AM
yes its worth it, the engine has 40 more hp.
Stan
V6Convertible is offline
post #3 of 9 Old 10-28-2006, 12:13 PM
yes it is worth it sense you already have it, i would get some goodies from Super six to for even more power if you can afford it, they both use the 4R70 auto,
09 f-350 lariat CCSB 5.4 - DD
04 f-350 RCLB 6.0 - sold
mustangman022232 is offline
post #4 of 9 Old 10-29-2006, 05:46 PM
its well worth the swap i did it and i would do it again in a heart beat
ProCharged Splitport Powered 1995 v6
95sn95 is offline
post #5 of 9 Old 10-30-2006, 08:39 PM
it is worth it by a lot. i currently have a 03 in my 96.
you will need the engine harness if switching just the engine.
the trans will work but it is more of a hassle.
you will have to change wiring cause of the fact that the gauge cluster is electronic unlike your 95's.
pm me with any concerns or questions.
i'd be glad to help.....
96v6stang is offline
post #6 of 9 Old 10-30-2006, 09:58 PM Thread Starter
Thanks, guys sounds like it is well worth doing. 96v6stang I sent you a PM.
lx351 is offline
post #7 of 9 Old 11-01-2006, 10:12 PM
i used the 99+ engine complete and used my 95 wiring harness all worked out fine i used my 95 tranny and all was fine
you do not need to change all the wiring to make the 94-98 ***** work on the 99+ engines
95sn95 is offline
post #8 of 9 Old 11-05-2006, 12:24 PM
exactly. all you do is splice out some connectors from the new harness into your original harness. now about the new trans, thats a different story. i've heard different ways of making it work....
post #9 of 9 Old 02-01-2007, 07:26 PM
ive got my 95 tranny and clutch and fly wheel on my split port engine in my 95 car
mind you i blew them up at the end of this season but non the less they will work
95sn95 is offline
