Look at putting cobra brakes on my 2001 V6 - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 10-08-2006, 01:23 AM Thread Starter
Kingpony's Avatar
what parts do I need to upgrade
Kingpony is offline
post #2 of 5 Old 10-12-2006, 09:44 PM
Cobra Rotors, The calipers, pads, that should be it, you can reuse the factory brake lines, however you will most likely need to modify/remove the stock dust shields or buy the cobra dust shields.
Brian_O is offline
post #3 of 5 Old 10-31-2006, 06:50 PM
wheels
Truckin306 is offline
post #4 of 5 Old 11-05-2006, 12:27 PM
if your also upgrading the rear to cobra rotors you can use your stock calipers. but you will need cobra brake pads and cobra caliper brackets,
checkout sn95brakes(dot)com
96v6stang is offline
post #5 of 5 Old 11-05-2006, 05:37 PM
I have a brand new set of axle flange brackets that are used to convert the V6/GT brakes over to the Rear Cobra 11.65" setup. PM me if interested. You might also want to know that you'll have to either grind the caliper brackets (very easy to do) to clear the wider vented rotors or just purchase new Cobra specific brackets. I wouldn't worry too much about running dust shields-many people don't without any bad results
5driver0 is offline
