valve tapping??? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 10-03-2006, 12:26 PM Thread Starter
Angry valve tapping???
I just bought a 99' v6 and it seems like it has a valve tap when i start it up. the previous owner said that it is probably from sitting for about 6 months. it kinda goes away as the motor warms up but how bad is this, and how can i fix it??? any help is appreciated...
Five.0hh is offline
post #2 of 7 Old 10-08-2006, 11:50 PM
a lifter sticking? try taking off the oil filter (just the filter) and drain it, reinsall it and top off the oil with some ATF tranny fluid, then fill up with either shell v power or chevron gas (with techron) and run it, it should go away in a bit
09 f-350 lariat CCSB 5.4 - DD
04 f-350 RCLB 6.0 - sold
mustangman022232 is offline
post #3 of 7 Old 10-13-2006, 11:28 PM
h82lose's Avatar
Don't run transmission fluid in your engine for very long. If you don't feel safe putting transmission fluid in your crankcase, try an engine treatment like seafoam. I've used it and it works very well. Drive it for an hour or so, then drain it. Do it right before an oil change so you don't waste money as well.
h82lose is offline
post #4 of 7 Old 10-15-2006, 07:22 PM
X2, i wouldnt run it for more then a week or 250 miles should of mentioned that
post #5 of 7 Old 10-16-2006, 08:17 PM
Check your exhaust manifold for a leak on the passenger side. I have run in to two with exhaust leaks that sound just like a lifter, and one broken exhaust spring. Ford knows that have a problem, but on recall so far. Good Luck.
uscggruski is offline
post #6 of 7 Old 10-20-2006, 04:14 PM
exhaust leaks dont go away
post #7 of 7 Old 10-20-2006, 10:01 PM
Check Ford Service Bulletin Number 041003 or NHTSA item number 10013368, read the full report.
