Pinging - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 09-26-2006, 09:23 PM Thread Starter
TTU
Pinging
I have a 2000 v6 with approximately 80,000 miles on it. The car will not stop pinging. I replaced the fuel filter, cleaned the injectors (and throttle body) put a K & N air filter it it, and even took it to Firestone for one of thier "stop pinging treatments--I believe this is to clean out any backed up carbons in the cats"--none of this has worked.
Is there anything else I can do? replace MAF? I also strated using higher octane gas--same result. Thanks in advance.
TTU is offline
post #2 of 6 Old 09-26-2006, 11:46 PM
I always put Premium in mine and never have a problem.. Give it a little bit after using the higher premium gas maybe put an octane booster in it, just incase u mixed the old gas new gas and the octane still isnt high enough..
ragedlonewolf is offline
post #3 of 6 Old 09-27-2006, 08:49 PM
premium is useless unless you have a tune, you might of just gotten cheap gas thought
09 f-350 lariat CCSB 5.4 - DD
04 f-350 RCLB 6.0 - sold
mustangman022232 is offline
post #4 of 6 Old 09-27-2006, 11:44 PM
my car runs different if i dont put in premium..
post #5 of 6 Old 10-13-2006, 11:18 PM
h82lose's Avatar
Sure there's plenty you can do. I would start with spark plugs and wires. If that doesn't help, check the coil pack with a multimeter. That should get you on the right track. There isn't a check engine light is there?
h82lose is offline
post #6 of 6 Old 10-15-2006, 07:20 PM
then its either in your head or your getting cheap gas, if your car isnt tuned for premium, or running F/I (which requires a tune anyways) then you have no reason to run premium
