vibes - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 09-16-2006, 06:14 PM Thread Starter
BOBBY WARD's Avatar
vibes
questions
not having had a 6cyl before (kids car) this car has some vibes around 60 or
so that seems to come from the engine maybe, it does have some vibes when the a/c is on at idle, are these common problems ?
i rebuilt the front end and put on new hubs, tires are new and all that good stuff but the same old problem, has a vibration i can't figure out where it comes from , anyone have any clues ? the motor mounts are good and tight
also as i have checked all things that seem like usually cause problems and mine all seem to be good ?
thanks for any input
bobby
82 gt w/93 cobra eng-trans x over + more
01 mustang 6cyl , gt wanna be
93 gt finished , another 93 gt going through the chop cut and rebuild process now
BOBBY WARD is offline
post #2 of 4 Old 09-25-2006, 10:39 PM
tire balanced? seals on tranny? Are you loosing in tranny fluid?
ragedlonewolf is offline
post #3 of 4 Old 09-26-2006, 09:51 AM Thread Starter
BOBBY WARD's Avatar
thanks
no leaks and all was new
i have looked and looked and just missed this
the trans mount was broken
that must explain why it had vibrations at odd times
post #4 of 4 Old 09-26-2006, 08:08 PM
O fixed! That would explain! best of luck
