3.8 to 4.6, i need help!!! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 25 Old 08-27-2006, 10:46 PM Thread Starter
ok i know its possible 2 convert a v6 to a v8 but im not sure of what all i need. i have a 97 mustang v6 with an automatic transmission. a guy i know has a 97 mustang gt. he's willing 2 sell me all this: 4.6 engine: 96 bottom end with the complete PI conversion heads, intake, cams, cast BBK valve covers, Long tube headers, Pro chamber x-pipe, Cat converter eliminators. K member solid motor mounts. Engine has PS, alt, and AC eliminator pulley and bracket, T45 Transmission (Racing Clutch pressure plate and TO bearing are not included), Hydra boost brake booster lines. Wire harnesses, computer, included, computer and HIPO chip. what i wanna know is what else do i need 2 complete this conversion? someone please help me!!!
thanks
red97mustang is offline
post #2 of 25 Old 08-29-2006, 09:50 AM
The wiring harness is the hard part..
Im making 320 rwhp with a v6..why go v8?
Stan
V6Convertible is offline
post #3 of 25 Old 08-29-2006, 11:43 AM
Pythias's Avatar
Maybe he wants that rumble that you simple can't get with a V6.
Pythias is offline
post #4 of 25 Old 08-29-2006, 12:21 PM
you should hear my car with longtubes, custom h pipe, magnaflows into turndowns..beleive me it rumbles
Stan
post #5 of 25 Old 08-29-2006, 08:56 PM Thread Starter
what did you do to get 320 horses out of your six?
post #6 of 25 Old 08-29-2006, 10:24 PM
Radiator, Instrument Panel, exhaust that is all the big stuff
Massarian is offline
post #7 of 25 Old 08-29-2006, 11:28 PM
ok here is the list of just engine work
01 splitport motor
Heads and intakes ported and polished
Hypercoated mac longtube headers
Custom h pipe
Magnaflows and turndowns
Vortech V1 supercharger with 2.87 pulley(17lbs of boost)
Snow perfomance water methanol injection
SCT chip and dyno tune
The car is set up for autocross/road race and i have alot more in the suspension than i have in the engine.
Stan
post #8 of 25 Old 09-02-2006, 09:44 PM
01 splitport motor
Custom h pipe
Stan
Those numbers seem a bit low especially with a bascially intercooled vortech setup at 17lbs of boost.I would of figured from what i have seen you would be beyond 350 and almost near 370 hp area especially with port and polished heads and intakes and a bad ass flowing exhaust. A bone stock splitport with a vortech unintercooled at 6-8 psi makes near 230 hp. add the injection your close to 270 rwhp and the boost and heads should put you at 350. What kind of dyno was used? How are you geared?
Blown95sixer is offline
post #9 of 25 Old 09-03-2006, 05:09 AM
The limitation is inlet air temperature. the Water injection isnt enough to bring the temps down where they need to be to add enough timing. If I install a water to air set up im sure i could hit those kind of numbers.
4.10 gears on a Dynojet
Stan
post #10 of 25 Old 09-03-2006, 04:04 PM
Stan
whatcha got done
Custom 232 and 3.8 emblems for you 94+ V6 Ford Mustang
EVal95 is offline
post #11 of 25 Old 09-03-2006, 05:35 PM
Stan
I think you should try going that way. You are deffintly not getting all the potential out of the setup. me and eval are both vorteched also. I have a v2 though. What is your best e/t.
post #12 of 25 Old 09-03-2006, 06:33 PM
thanks
not worth it, its alot cheaper to build up the V-6 if you know what you are doing
super six motor sports
tma turbo
VMP tuning
look at junkyards for an M-90 supercoupe motor
its very easy to do a turbo build up on fords essex 3.8, basically its a modified copy of buicks grand national motor, and have you ever heard its a waste of time to build a turbo buick? didnt think so
fords 2V mod motor is a peice of garbage, dont bother with it
09 f-350 lariat CCSB 5.4 - DD
04 f-350 RCLB 6.0 - sold
mustangman022232 is offline
post #13 of 25 Old 09-03-2006, 07:22 PM
tma turbo
VMP tuning
well put!!! I wouldnt go as far to say the 2v mod motor is worthess.
post #14 of 25 Old 09-13-2006, 03:23 AM
whiteboy281's Avatar
its a easy swap done one already
2011 5.0
and many more!
whiteboy281 is offline
post #15 of 25 Old 09-14-2006, 11:29 AM
Pythias's Avatar
Yes because there are so many 2v that make the 3.8 look fast.
Honestly now.
I give props to V6 convertible, those are some decent numbers, but at the cost of 17 pounds of boost.
Pythias is offline
post #16 of 25 Old 09-14-2006, 05:24 PM
Honestly now.
would u rather pay 5 grand for two letters and 60 HP or 5 grand and 100 rwhp but no letters?
post #17 of 25 Old 09-14-2006, 06:33 PM
A 2v swap should not cost 5 grand. More like $2,500 max if you shop around.
I would have bought one of the two cars listed below had I not already gotten a killer deal on a complete engine with all the wiring.
Here are two donor cars that I was watching on ebay:
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Not to mention that you can sell off extra body parts thus lowering your cost even more.
For us pre 99 v6s who have 150hp vs same year GT's 225 makes it a 75hp upgrade.
That means adding 100hp to your V6 at 5 grand is $50 per hp
The 1 grand V8 swap comes in at $13 per hp
Now that wrecked GT's have come way down in price it is way more cost effective to swap IF you do it right.
post #18 of 25 Old 09-16-2006, 08:28 AM
Used v1 kit $1500
Headers and exhaust $500
Snow kit $300
Sct chip and tune $400
a lot less than 5 grand
and I pay v6 insurance and get v6 gas mileage...
Stan
post #19 of 25 Old 09-16-2006, 11:47 AM
What you have done is pretty impressive.
However red97mustang asked about a v8 swap. Everyone made it seem impossible or crazy expensive like 5k. There are several ways to make power and I just wanted to give the info I had that a v8 swap is a viable option.
red97mustang: Check 3.8mustang for more info. I've posted several times about wiring changes that need to be made. That's sort of my specialty.
post #20 of 25 Old 09-16-2006, 10:15 PM
Pythias's Avatar
Wrong, I responded to you insulting the 2valve modular motor, because according to you it is, what, inferior? Now WHILE the best bang for the buck MIGHT be to supercharger the V6, that is besides my post. All I did was defend the motor because, it isn't a piece of sh*t. As for best bang for the buck, yeah supercharge the V6 if you want to have to use 17 psi just to obtain 300rwhp, or you could swap in the V8, find a used 8psi supercharger for about 1k or so, and have quite a bit more power, with less than half the boost.
Pythias is offline
post #21 of 25 Old 09-16-2006, 10:24 PM
I could have considerably more Hp with either a turbo or a intercooler
We have people hitting 500hp on www.v6power.net(and running 9's)
Stan
post #22 of 25 Old 09-16-2006, 11:13 PM
Pythias's Avatar
I realize thatalthough I thought 9's was the fastest any V6 Mustang ever ran.
Pythias is offline
post #23 of 25 Old 09-17-2006, 12:18 AM
We have people hitting 500hp on v6powerrunning 9's)
Stan
only one currently in the 9s i thought was matt from delk preformance
post #24 of 25 Old 09-18-2006, 02:17 PM
Pythias's Avatar
I believe thats right, I remember the thread, and there are a few others in the 9's, but not many.
Pythias is offline
post #25 of 25 Old 09-19-2006, 09:16 PM
supersix could probably get there easily, as could justin at VMP, other then that idk
