V6 EFI vs Carb - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 08-13-2006, 04:51 PM Thread Starter
quikstang2's Avatar
V6 EFI vs Carb
I took the 3.8L out of my '84 'vert and put it in another '84 coupe with a blown motor to try and resell it and make a little money. Between what's left of both the EFI systems the thing won't run right...or just won't run. I know the 'vert had a Cougar computer in it, so that may have caused some issues.
I saw an '83 3.8L at a local junk yard and ripped off all the parts that I thought I needed to carb it.
For some reason the distrubutor shaft is shorter than my EFI one and won't reach. Is there something else I need to get ahold of to make this work?
Also, is there an aftermarket carb intake manifold I can get or am I going to end up filling in a bunch of holes left by the sensors and smog crap that I don't need?
thanks,
mike
quikstang2 is offline
post #2 of 3 Old 08-16-2006, 01:11 PM
88CougarCoupe's Avatar
somewhere i know their is a 4brl. carb intake someplace. i'll have to search the net. but i was gonna do it with my 3.8
Performance Automatic C4, TFS steet heat intake with 1inch spacer, GT-40's long tube headers, 24lbs. injectors, 65mm tb 3g alt Jegs Aluminum radiator., taurus fan (DCC)... and some Maximum Motorsports stuff, 5 lug w/ Bullets..... no numbers yet
88CougarCoupe is offline
post #3 of 3 Old 08-16-2006, 09:42 PM Thread Starter
quikstang2's Avatar
Yes there is a 4brl carb conversion: http://www.moranav6racing.com/
They have everything.
Another bit of info I found is that there were two distributors for the '83 Stangs and the part number for CA and FL is #E3ZE12127.
Couldn't find anything about oil pumps being different which is what my dad thinks may be the problem.
