3.73 gears and T-loc - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 07-28-2006, 01:32 PM Thread Starter
So pretty soon im going to install FRPP 3.73 ring and pinion gears along with a Ford Trak-Loc positron limited slip differential. My question is, do I still have to buy a bearing kit for the installation or does the T-loc take care of that? Any help is greatly appreciated!!!
Duntless6 is offline
post #2 of 4 Old 07-28-2006, 03:21 PM
I would suggest you use new bearings for this job. I've heard of others that were able to reuse the old bearings, but I wouldn't even attempt this unless you have very few miles on the existing setup. If you're gonna go through all the expense and effort to put in new gears and t-lok, spend a little more knowing you've done it right.
pony ride is offline
post #3 of 4 Old 07-28-2006, 07:42 PM
buy a master rebuild they run about 115.00 they will replace everything. make sure it has the axle shaft bearings(wheel) to those usually go bad before anything else over time.
Do it right the first time and u should get years out of it. mine had over 75k on it and nothing ever leaked
flamingpony is offline
post #4 of 4 Old 07-30-2006, 02:48 PM Thread Starter
OK thanks guys! Ill probably get the full kit.
