Aluminum Driveshaft ... - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 7 Old 07-20-2006, 11:53 PM Thread Starter
Will the aluminum driveshaft for the 4.6 (M-4602-J) also work w/the V6?
'98 GT equipped w/Koni, Eibach, Cobra R rims w/Yokohama tires, Cobra brakes all around & 3.73 gears. Also a Boss330 4.6 Cobra block w/PI heads & stuff from Accufab, ARP, Centerforce, Comp Cams, Fidanza, K&N, Mahle, Manley & Borla exhaust w/Mac Pro Chamber thrown in for grins & giggles.
Geezer is offline
post #2 of 7 Old 07-21-2006, 11:17 AM
yes they are the same actually the fox body shafts will also work as they are also the same.
mustangraven is offline
post #3 of 7 Old 07-21-2006, 02:34 PM Thread Starter
Just what I wanted to hear. THANK YOU!!!
Geezer is offline
post #4 of 7 Old 07-22-2006, 12:05 AM
It worked well on my 95. It made the car much snappier.
K
2008 HG Bullitt #3594
kempesh is offline
post #5 of 7 Old 07-25-2006, 11:17 AM
no problem if you have an auto you will have to swap yokes but its easy to do I had mine done in about an hour or 2 most of the tme was spent getting the car up and putting in a new rear trans seal man those things suck big time!
post #6 of 7 Old 07-31-2006, 02:29 PM
Hey what advantages does an aluminum drive shaft give over stock? Is it that the aluminum driveshaft is lighter and thus requires less energy to spin (i.e. a smaller moment of inertia)?
Duntless6 is offline
post #7 of 7 Old 08-08-2006, 07:37 PM Thread Starter
Duntless6 ... "What advantage does an AL d/shaft have over stock? Is the AL d/shaft lighter & requires less energy to spin?"
BINGO!!!
Geezer is offline
