Cam sensor help on 1995 - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 1 Old 07-15-2006, 02:46 PM Thread Starter
Engine light came on and gave me a PO340 code that the cam sensor was bad. Went to check the sensor per the book and it told me to expect a 0-5V signal when the engine is rotated by hand. Instead, I am getting 0 or 12VDC. Is my sensor bad, or is the PCM having a problem getting a 5V signal to the sensor ? Thanks for the help.
Matthew
matthewx is offline
