fog lamp kit - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 1 Old 05-20-2006, 05:56 PM Thread Starter
fog lamp kit
I've just installed an oem fog light kit from Ford that has two relays. I have to use this in order to pass inspection. On the diagram that came with the kit, it shows a yellow wire going to the positive side of my battery and then has a green w/black trace wire going to the console switch. This wire is too short to reach the switch. Do I need to splice into the high beam circuit to make this work? Where exactly do I connect this wire(green w/black) so that it works with the system.(automatically dims when I go to high beam)
Any help with this would be greatly appreciated.
P.S. I have a 2000 3.8 Mustang.
wangrman is offline
