Replacing 95 3.8... what year to use? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 19 Old 05-11-2006, 06:06 PM Thread Starter
I am thinking about replacing the overheating 95 3.8.
What year engine should I look for 96,97,98, or?
What else will I need to get to do the swap?
tas
sarahsmustang is offline
post #2 of 19 Old 05-11-2006, 09:36 PM
Since you're doing an engine swap anyway, I'd recommend getting a 99-04 (split port) 3.8 . It's almost a direct swap, but a few other minor things have to be changed (ex: Fuel rail). Well worth the minor oddities for an extra 40-45hp.
Cougarstang is offline
post #3 of 19 Old 05-11-2006, 10:00 PM Thread Starter
Sounds like the right direction.... Can anyone else add to this?
What else will be needed to make a 99-04 fit and run properly?
tas
post #4 of 19 Old 05-12-2006, 11:09 AM
Visit www.v6power.net and search for split port swap. Youll find dozens of articles. I would reccommend an 01 and up v6 if you can find one. They are zero balalnced and have a nice main girdle stock.
Stan
V6Convertible is offline
post #5 of 19 Old 05-12-2006, 11:20 AM
split port is definitly the way to go. you will need the coomputer engine wiring harness and also I modified fuel rail which you can get pretty easy or do yourself as the 99-04 is returnless style and the 94-98 has a return line not too bad to do from what I hav read. one of the moderators sells the modded fuel rails over at 3.8mustang.com
mustangraven is offline
post #6 of 19 Old 05-13-2006, 09:33 PM
v6stang95's Avatar
You will not need the 99-04 engine harness. All you will have to do really is extend some wires for the 99+ swap. Its worth it if your looking to mod the car.
Are you going to try to swap the head gaskets first on the 95 to see if thats the problem which very well could be, but if she's going to street race this car every now and then I'd go with at least a 96-04. 96-98 will require different water pump hoses though, and a 98 might need the 98 EGR tube, or you can just delete it.
v6stang95 is offline
post #7 of 19 Old 12-12-2006, 03:33 PM
cobraman1024's Avatar
Trader Feedback: (69)
WHOOHOOO!!!! i finally got a 2001 3.8L for my girls 95 v6 lol.......ok, i'm an idiot for bragging; can't blame me though, i got an awesome deal on it.
-1995 Cobra #182/4005; 305hp/ 300tq, 231k miles, Roush intake, export parts
-1996 Mystic Cobra #1666/2000; 351hp/309tq, 221k miles, built 284, H/C/I, ARH, Mezeire, LMAF, JLT, MM suspension
-1993 Mustang LX, 2.3L w/ T5 conversion, AJE/MM suspension w/ 8.8, 03 Cobra steering/brakes, 271k miles
cobraman1024 is offline
post #8 of 19 Old 12-12-2006, 08:46 PM
that is what's great about these motors, they arent really in demand so their cheap. I got my 01 3.8 short block for $200.
People ask me how i can run 17lbs of boost on a stock bottom end. I don't brag about the stout girdle and strenght of the 3.8 I just tell them they are so cheap they are disposable.
Stan
post #9 of 19 Old 12-12-2006, 08:52 PM
splitport swap woud be nice, you could get a motor from mpsautosalvage.com, another nice option which would be just as easy would be a motor out of a tbird supercoupe
09 f-350 lariat CCSB 5.4 - DD
04 f-350 RCLB 6.0 - sold
mustangman022232 is offline
post #10 of 19 Old 12-12-2006, 10:11 PM
i thought of the supercoupe transplant but theres too much fabrication involved in using the supercharger; not only that but if you were to use the SC cylinder heads you'd have a difficult time matching a lower intake to them-------only the SC lower intake will match the SC heads intake openings. oh yeah, and i paid $300 for my 21,000 mile longblock; complete intake to oil pan. so yeah i'm lovin' how cheap and readily available these things are.
post #11 of 19 Old 12-14-2006, 04:14 PM
just swap the whole supercoupe motor in
how cheap what is parts for the 3.8? its a great motor and it is cheap, to bad it hasnt been accepted by the hardcore mustang guys yet
BTW: get the heads milled .005 and checked for warpage, use new studs and bolts from ARP, and get 99+ mls headgaskets and you wont have the gasket problem
post #12 of 19 Old 01-07-2007, 08:26 AM
use a F150 4.2 shortblock have your heads re built and use the head gaskets mentioned above. enjoy the extra torgue
ginner is offline
post #13 of 19 Old 01-10-2007, 10:16 PM
plstktnkr2's Avatar
hey mustang man I am doing a supercoupe swap into an '84 lx vert with a stroker crank installed
'66 lincoln ragtop,
1983 Mustang convertable S/C V6
1985 Lincoln Town Car Hearse
Four-Eyed pony posse member
plstktnkr2 is offline
post #14 of 19 Old 01-26-2007, 06:01 PM
go split port the swap is easy as **** and its easier then a supercoupe swap
ProCharged Splitport Powered 1995 v6
95sn95 is offline
post #15 of 19 Old 01-27-2007, 10:57 AM
Tas, what have you decided to do? The 4.2 short block is the easiest but with split port heads it would even be more powerful in it's stock form.
02 Mustang GT,5 spd, magnaflow cat back,excalibrator I, march ram air
97 v6 Mustang,5 spd,v1 Vortech 14#'s boost,Jerry tune,Snow Water /Meth injection
ginner is offline
post #16 of 19 Old 01-28-2007, 01:09 AM
He's had his split port 3.8 installed and running since last summer.
No.. I'm not "Fast."
Originally Posted by fkurls1 View Post
Simply awesome! Its like you came down from forum mountain with two stone tablets...
Fast94CobraSVT is offline
post #17 of 19 Old 01-29-2007, 09:55 PM
that's great, thanks
ginner is offline
post #18 of 19 Old 01-30-2007, 12:50 PM
a 4.2 swap will be just as easy
post #19 of 19 Old 01-30-2007, 10:34 PM
plstktnkr2's Avatar
how about split ports and a 4.2 ? at least all you computer cars can use them, none of the 4-eyed cars can without going fuelie I believe. But I might be corrected
'66 lincoln ragtop,
