So I disconnected the plug to the CMP on my 1994 3.8... - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 04-20-2006, 04:47 PM Thread Starter
And absolutely nothing happened.
Thats right, NOTHING happened. No codes, No pending codes, and no change in performance. How the hell is the car managing the injectors with out the camshaft position sensor? I've had this long running idle miss/rough idle with this car. Is the computer defective? Also, when put an off road H on the car I never got a CEL either. Code scanner pulled no codes. And unless the previous owner put some uber custom tune into this 3.8 before I got it and the dealer didn't notice...I'd say some wierd **** is going on.
silentst2000 is offline
post #2 of 5 Old 04-21-2006, 09:49 AM
v6stang95's Avatar
Your sure the light is working right? Also check behind the kickpanel on the passenger side to see if a chip is installed. Is the car completely stock? If it is I doubt there's a chip.
v6stang95 is offline
post #3 of 5 Old 04-21-2006, 06:17 PM Thread Starter
Yes I'm sure the light works. The code scanner didn't even pick up anything and I'm pretty sure there is no chip.
post #4 of 5 Old 06-12-2006, 05:24 PM Thread Starter
Ok....
for the next trick...
I was working on my exhaust and forgot to plug in one of my o2 sensors that is on the driver side collector.(the main front o2) I just happened to notice after about 50 or 60 miles.
Guess what...No codes what so ever.
post #5 of 5 Old 06-13-2006, 12:02 PM
v6stang95's Avatar
Sweet. Just be glad you didn't mess up your engine w/o that o2.
