Best Brakes for the buck??? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 04-07-2006, 09:03 PM Thread Starter
So I've been doing research and looking for brakes. I've never installed them myself but I'm having a friend help me so hopefully in the future I will be able to do it on my own. He suggested Raybestos pads. I was also looking at the ford motorcraft pads, but wanted to see what you guys suggest. I don't really take corners at like 100mph or rag my car out, but I do mainly short distance driving involving frequent traffic. Also what tools will I need in order to replace the pads/ measure the rotors.
Thanks Justin.
3.8ICEMAN is offline
post #2 of 6 Old 04-08-2006, 11:00 AM
Sounds like the stock motorcraft replacement pads are right for you
Cougarstang is offline
post #3 of 6 Old 04-08-2006, 09:01 PM
Id go with ford pads or ebc greenstuff.. or hawk pads.. As for rotors i change mine every two years or 20k but i drive hard. For the front pads u will need a C clamp to compress the caliper.. The rear is tricky u will need a brake caliper tool from autozone or autostore the rear pads turn in.
flamingpony is offline
post #4 of 6 Old 04-12-2006, 09:19 PM
poorracerkid's Avatar
Hawk HPS!
92 LX hatch, T5 swapped, still a DD.
poorracerkid is offline
post #5 of 6 Old 04-12-2006, 10:00 PM
Hawk hp plus was a huge increase in stopping power for autocross, Their street pads would be a big improvement for you.
Stan
V6Convertible is offline
post #6 of 6 Old 04-13-2006, 09:38 PM
Yup, but depending on the year you may have to modify it to work... I did with my '01... When I did the brakes on my car I got the Napa cross drilled and slotted rotors for the front, and ceramic pads the whole way around...
Thanks, Joe Reichard
Toys: '04 Mustang Mach 1 --- **FOR SALE**
01v6stangpwr is offline
