1994 3.8L Belt Tensioner - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 03-29-2006, 09:03 AM Thread Starter
Dear Forum Dwellers:
Gotta change the water pump on this old mustang.
Can you give me a lesson on loosening up the belt tensioner so I can get the belt off?
I can get a T-50 star wrench where it looks like it is attached to the mounting bracket, but how much brute force do you suggest I use to try to loosen it up.
One of the posts on here said it might be a left handed thread, which would be really good to know before I put a big pry bar on there and put some muscle to it.
Suggestions?
pup55 is offline
post #2 of 3 Old 03-29-2006, 12:15 PM
90lxcp's Avatar
If it's anything like the 5 liter tensioner, just put your torx on a good long breaker bar with a bit of tubing over the end and use it to lift the pulley off the belt.
90lxcp is offline
post #3 of 3 Old 03-29-2006, 01:10 PM
Maybe this thread will help... This person wanted to reinstall their alternator, but the belt tensioner should be similar.
http://3.8mustang.com/forum/showthread.php?t=153398
Blainestang is offline
