how can i burnout with both tires - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 16 Old 03-22-2006, 08:06 PM Thread Starter
since i got my stang i have been doing many burnouts, but not in public places. I was wondering why i only leave/burnout with one tire. I was wondering how i can ake it burnout with both and give it more of a powerfull burnout. Any thoughts anyone.
P.S. anyway i can make it burnout with both tires?
red_stang_3.9 is offline
post #2 of 16 Old 03-22-2006, 08:23 PM
seawalkersee's Avatar
It appears form your sig that you have a 6cyl. If you want to put more bang in your stang, add a set of gears and a traction lock. You can get them at many places. If you are running stock, I suggest 3.55s. If you are going to upgrade to a better flowing engine, 3.73s would do you good. But to smoke them both EVERY time, you need a locker of some sort.
Chris
seawalkersee is offline
post #3 of 16 Old 03-22-2006, 08:46 PM
if u have a auto trans but in 4.10 gears if u have a 5 speed 3.73 would be fine. And yes u need a posi locker to spin both rear tires. I have a v6 and 3.73 gears with an auto didnt feel like a big difference
1994svtcobra is offline
post #4 of 16 Old 03-23-2006, 03:02 AM Thread Starter
where can i get the posi locker and around how much would it cost me, also what gears should i go with, my car just has minor mods, (CAI, CATBACK, SUPERCHIP, and HEADERS) for both the locker and gears, how much do you thick it will cost
post #5 of 16 Old 03-23-2006, 03:07 AM Thread Starter
i was checking the locker out and came up to this posi-traction 7.5 differential, 28- tooth spline, is this what i need?
post #6 of 16 Old 03-26-2006, 09:40 PM
v6stang95's Avatar
Yes. Go to GefRacing.com to get good priced ford rear end components.
v6stang95 is offline
post #7 of 16 Old 03-27-2006, 12:02 PM
You need a traction loc and 4.10's if you an auto.
Stan
V6Convertible is offline
post #8 of 16 Old 03-27-2006, 05:46 PM
or you could go to the next step and buy a GT differential with your choice of gears. it's much stronger than the 7.5
it's a fairly common practice
dark is offline
post #9 of 16 Old 03-28-2006, 11:48 AM
v6stang95's Avatar
Which is fine if he upgrades to an 8.8 rear end housing. And gets 8.8 gears also.
post #10 of 16 Old 04-10-2006, 09:50 PM
Juggalo5.0's Avatar
Trader Feedback: (15)
If he is trying to just waste tires, why not just change out to a GT rearend (8.8)? He doesn't really need gears to make the chicks wonder what is wrong with him. I bought the 8.8 in my fiance's Sixer for $125. That would leave plenty of money for tires as opposed to buying a locker and gears, or just a locker.
Alternative
Just weld up the spiders and get to the streets! It might be a little scary when it goes out but it should be one hell of a ride!
*15 years with my vert on 5-22-14*
The basic 1989 GT vert with a black interior swap, Cobra HCI and 5 speed swap. Other than that it is just your regular bolt on Pony but she has alot of things bolted on.
Juggalo5.0 is offline
post #11 of 16 Old 04-11-2006, 12:12 PM
v6stang95's Avatar
Red face
Alternative
+1, but its hard to find an 8.8 for $125 unless it needs a rebuild, but thats just me.
And I see in your name you've got a 3.9 which is the '04 which means you sure wont want a sn95 8.8 under there or your rear end is going to get 1 1/2" shorter (total) I believe.
post #12 of 16 Old 04-14-2006, 11:07 AM
SVTHorsnake's Avatar
why the hell are you people telling this poor kid to go make his car uncomfortable with a locker?
just get a facotry LSD from junk yard or something.
‘01 Cobra - Built Teksid, LFP Cooling Mod, 70 mm Turbo, SCT 2400, 42 lb Injectors, twin focus pumps, Centerforce S3, B&M Short Throw, L5 DSS Halfshafts, QA1 K-member/Control Arms, MM Coilovers/CC Plates/Bumpsteer Kit/Rack/Pinion Drop Kit, Bilsteins, Brembo GT Brake Kit, Full Roll Cage
SVTHorsnake is offline
post #13 of 16 Old 04-14-2006, 01:20 PM
v6stang95's Avatar
Ahhh I just saw that. Yes a locker is different from a traction lok. You want a t-lok for your street use. I wouldn't get a used t-lok, but thats just me...
post #14 of 16 Old 04-14-2006, 08:47 PM
killacal's Avatar
Get a spool, or a ghetto-spool(weld the rearend up). That'll be a garunteed posi burnout.
'89 Notch TT w/ custom tunes by Cal
killacal is offline
post #15 of 16 Old 04-19-2006, 02:56 AM Thread Starter
by doing this to my car would it increase or deacrease any HP or Trq and the reason i want to do this is when i actually step on it i looks kinda dumb with only one tiremark escecially in races
post #16 of 16 Old 04-19-2006, 09:29 AM
v6stang95's Avatar
Neither. It will feel like a tq increase by the butt dyno, but other than that it will allow you to get into your powerband quicker.
