too many miles?? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 14 Old 03-14-2006, 08:57 AM Thread Starter
too many miles??
my car has about 118,000 miles on it . how much longer do i have until it starts having serious problems?? it runs fine but every once in a while it has have trouble starting. what are a few things i could do to get my car to last longer??
bluestang1724 is offline
post #2 of 14 Old 03-14-2006, 11:56 PM
It really depends on how well it's been cared for. Also, age is another factor. I've seen an 86 continental with only 45k miles have problems strictly from its age. What year is your car?
You can get your car to last longer if you follow the maintainence schedule religiously
Cougarstang is offline
post #3 of 14 Old 03-18-2006, 01:22 PM Thread Starter
it is a 00' 5 speed and the person who had it before me didnt take much care of it
post #4 of 14 Old 03-19-2006, 05:52 PM
Basic maintinance would help improve the longevity of the motor and the car.
Regular oil changes
Check the spark plugs, wires
Regular fluid checks antifreeze, tranny, power steering etc...
Serpentine belt
Tranny service
Flush and fill radiator
Checking your Ford book in the glove box or calling a Ford dealer will tell exactly when and what needs to be service by milage. However doing the work yourself will be considerably cheaper than having the dealer do it.
BootlegGT is offline
post #5 of 14 Old 03-21-2006, 02:38 PM Thread Starter
about how many miles until i start having problems?
post #6 of 14 Old 03-21-2006, 08:13 PM
There is no way to tell. There are 100s of variables that determine everything that could go wrong with a car, from what type of weather the car has been driven in to the manufacturers tolerances on the stock parts.
post #7 of 14 Old 07-24-2009, 12:26 AM Thread Starter
wow i remember posting this a wayyyy long time ago! lol.. and o by the way the car has a lil over 156,000 miles on it now! and not a single problem!
tfs track heat heads, tfs track heat intake, Pushrods, Valvesprings, lunati cam, ross forged aluminum pistons, 24lb injectors, 255lph fuel pump, bored .030 over, BBK equal length shorties, mac O/R h-pipe, flowmaster 40s w/ turndowns, MSD 6AL, blaster Coil, MSD Dizzy, TR-3550 Trans.
post #8 of 14 Old 07-24-2009, 04:51 PM
Good to hear. Keep up with your maintenance, Change your oil regularly, and you might be surprised how long it lasts.
svtcobra1998 is offline
post #9 of 14 Old 07-25-2009, 05:07 PM
plstktnkr2's Avatar
my 1984 v6 has well over 160,000 (I know is been turned over at least once) and she is still kicking flat tappets and all
'66 lincoln ragtop,
1983 Mustang convertable S/C V6
1985 Lincoln Town Car Hearse
Four-Eyed pony posse member
plstktnkr2 is offline
post #10 of 14 Old 07-25-2009, 05:19 PM
plstktnkr2's Avatar
double post
'66 lincoln ragtop,
post #11 of 14 Old 08-02-2009, 12:38 PM
191,000 on my 4.6 F-150 and uses no oil between 3K changes....
snkmug is offline
post #12 of 14 Old 08-21-2009, 01:00 AM
onyxblue 97's Avatar
I have a 2000 V6 w 120000 miles only changed oil and tires.....
Less maintenace than my Mercedes about the same age & mileage.
Will change the rear main seal which i just noticed started to leak !
onyxblue 97 is offline
post #13 of 14 Old 08-31-2009, 07:22 AM
I have a 98 v6 mustang with very few problems over the years. The few problems I've had were mostly my own fault. Now I think the walbro 255lph pump I installed 8 years ago is going out on me.
First post, looks like a good site, loads of information on all different types of mustangs, but what happened to the v6 side?
blackfury is offline
post #14 of 14 Old 08-31-2009, 09:05 AM
Domingoakasunday's Avatar
There are 2 forums dedicated just to us v6 guys out there, so I doubt there are many who come here for serious information.
2000 mustang convertible 5-speed
17x9 & 17x10.5 anthricite bullitt wheels with 315/35/17 nitto 555s on the rear, tinted windows, sequential tail lights, Mac LT ceramic coated headers, duals 2.25 flowmaster 50s, cut Bumper, Ebay CAI, spec stage 2 clutch
Domingoakasunday is offline
