another side exhaust question - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 03-13-2006, 09:02 AM Thread Starter
if i were to get side exhaust would i have to get new side skirts or will the exhaust go under the side skirt?? or would it look ok to just cut a hole the size of the exhaust tip?
bluestang1724 is offline
post #2 of 4 Old 03-16-2006, 08:24 PM
unless you were getting the roush side exhaust (in which case you'd need the side skirt) you could have a custom side exhaust that would lie perfectly underneath your stock sideskirt as i had with my car. except i took it off because it ends up being about 2" from the ground and it can be ripped off just going over a steep driveway
hopeful is offline
post #3 of 4 Old 03-17-2006, 02:30 AM
You should look for a side exhaust kit that comes with the side skirts, there are some around but they do cost a little bit extra. Its worth it though at the end it would look way better than if you cut holes in them. I was going to get them but i decided to go with a regular dual exhaust
red_stang_3.9 is offline
post #4 of 4 Old 03-18-2006, 01:25 PM Thread Starter
i thinkits the roush kit
