im trying to take off the fuel rail - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 02-09-2006, 08:39 PM Thread Starter
wuz up
ok im taking off my heads,and im trying to take off the fuel rail.what im haveing a hard time with is .
1 how do i get the line off the rail
2 do you have to use a tool
3 what dose it look like
4 what part of the line is it that comes off
i have a 98 mustang 3.8L
post #2 of 8 Old 02-16-2006, 11:25 AM
v6stang95's Avatar
Originally Posted by [email protected]
wuz up
Look over at the passenger side and you'll see two wierd looking connectors. You'll need to buy a fuel rail/ac disconnector tool that you can get from your local auto parts store. You dont need to take the fuel rail off completely unless your replacing it. You can just move it out of the way. Sometimes its a pain to take off even with the tool.
v6stang95 is offline
post #3 of 8 Old 03-08-2006, 03:21 AM
I need to take my heads off for head gasket replacement. I don't have to disconnect the fuel rail, right? Do the injectors stay connected to the fuel rail or should the fuel rail be removed then pull the injectors?
5.0HO is offline
post #4 of 8 Old 03-08-2006, 03:56 PM
I just did a head gasket job with my dad on a 93 3.8 cougar
We took off the fuel rail and popped out all of the injectors. You'll basically be stripping the engine down to the block. I'm actually not sure if you can get around not taking the fuel rail completely off
Cougarstang is offline
post #5 of 8 Old 03-09-2006, 04:15 PM
v6stang95's Avatar
There's no reason for you to have to take out the injectors, and unhook the fuel rail on a mustang especially 94-98. If you do take off the injectors be ready to leak a little bit of gas everywhere even though you might have already disconnected the fuel cutoff. Good luck with those headers though. Your going to be pissed after trying to get those headers back on the heads again.
post #6 of 8 Old 03-10-2006, 02:26 AM
I'm not following you here. It looks like the injectors are in the heads? I was hoping to leave the rubber fuel lines connected and just remove the fuel rail/injectors and lay them to the side...
5.0HO is offline
post #7 of 8 Old 03-21-2006, 04:09 AM
fuel rail disconnect tool can be purchased at any auto parts stores. seems like i paid 5 or 6 bucks with a package that had 6 or so of them.
MaroonMustangGT is offline
post #8 of 8 Old 03-22-2006, 01:27 PM
v6stang95's Avatar
I thought you meant taking the injectors out or 'off' of the fuel rail. Yea just give those suckers one little tug and you'll get em out of the head.
