Got a supercharger for V6 engine and.. - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 02-08-2006, 05:46 PM Thread Starter
Trader Feedback: (25)
Dont know if I should use it or what. Has anyone got a set up with this? Its the factory Ford supercharger for 3.8 engine out of Thunderbird Super Coupe and I have everything here to go with it. Thanks for any help/.
5.8 TurboCoupe is offline
post #2 of 9 Old 02-08-2006, 06:10 PM
From what I heard in passing threads back in the day, there's alot more that you have to swap over to get it to work correctly
Don't forget though, the supercoupe's 3.8 had forged internals, the stock mustang's does not
Cougarstang is offline
post #3 of 9 Old 02-08-2006, 09:00 PM
only the sc rods were forged and even then they still bent due to the high tq in higher hp cars. if u have a 94-98 v6 it will work no probs just need to swap alot of parts if u have the engine its even better
flamingpony is offline
post #4 of 9 Old 02-09-2006, 10:47 AM
It would be far cheaper to swap a supercoupe engine than to try to make it work on a mustang 3.8.
Sell it to someone else and buy a vortech
Stan
V6Convertible is offline
post #5 of 9 Old 02-09-2006, 01:16 PM Thread Starter
Yeah I have the whole SuperCoupe engine here.
post #6 of 9 Old 02-10-2006, 12:35 PM
its been, done. i did the swap with my supercoupe blower and put it on my 5.0L.
you can check out my thread here: https://www.corral.net/forums/showthread.php?t=752515
Also, check out www.sccoa.com (these guys are great when it comes to supercoupe related modifications!!!)
- Jim
87 Hatch.
5.0L w/S-Trim + supporting parts
JimBowy is offline
post #7 of 9 Old 02-10-2006, 12:43 PM
Good call . I didn't know that. I thought the crank was forged
post #8 of 9 Old 02-16-2006, 11:22 AM
v6stang95's Avatar
It is. Except for the very early one's which I dont know how many, if any, made it out to the public.
v6stang95 is offline
post #9 of 9 Old 02-19-2006, 07:42 PM
89's had cast cranks. Shortly after Ford went with a forged crank. As far as the rods being forged, uhhh, no. The pistons were Hypers.
Guys on the SCCOA are running over 400 at the wheels on stock bottom ends and so far they have been holding up. Granted most of our cars are getting older, so it doesn't quite help things when you modify the motor and expect it to perform.
I would suggest if you want to know more about the 3.8 that the SC offers, it may pay to visit the SC sccoa. Good luck
BTW, I have 2.3 Whipple made for the SC. To my knowledge it the last running 2.3 around that was made custom for the car. Originally there was only 3.
If anyone is interested, drop me a line.
Skip
V8Supercoupe is offline
