Signs of bad head gasket? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 02-06-2006, 10:14 AM Thread Starter
my girlfriend just got her first stang and it's a 97 v6...she bought for $1000 with a bad engine, but they said it could just be a bad head gasket to fix it
so before we go tearing apart i just want to know some symptoms or signs of bad head gaskets..thanks!
CobraSvt9646 is offline
post #2 of 4 Old 02-06-2006, 05:10 PM
If the car is driveable, You'll have no heat inside, and the temp guage will show overheating. And of course it will "use" water from the overflow. If You have access to a leakdown tester, that would narrow it down to which cylinder/cylinders is bad. Or, you could get a radiator pressure tester, and do it that way. (I don't like the idea of pressuring water into a cylinder) Your just about guaranteed that if the gaskets haven't already been replaced, they'll need to be. I don't know of a 3.8L (pre MLS gasket as O.E.) that hasn't had them replaced. If it is just gaskets, I think you got a smokin' deal on the car, it's an easy fix.
351 svo is offline
post #3 of 4 Old 02-06-2006, 11:44 PM
Was just reading over at 3.8 mustang dot com about a similiar problem. The agreement over there is that by late '96 Ford had the problem licked. But didn't come out with the MLS gaskets until '99. Just makes it that much more important to check things over before ripping into it. Good luck, and whatever it is, You still got a good deal.
351 svo is offline
post #4 of 4 Old 02-07-2006, 11:44 PM
I agree. I'm over at 3.8mustang often. The general consensus is that ford fixed the problem on the mustangs in 96, so the bad gasket plagued 3.8 mustangs are 94-95's.
Head gaskets do blow otherwise though, so you never know
Are you losing ALOT of water? Also, what's coming out of the tailpipe?
Cougarstang is offline
