H-pipe? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 12-31-2005, 02:50 PM Thread Starter
H-pipe?
Will a o/r H-pipe off of a 87-93 5.0 fit on a 99 V6?
stangracer43 is offline
post #2 of 4 Old 01-01-2006, 04:24 AM
Nope, not without some modification and a blow torch
Cougarstang is offline
post #3 of 4 Old 01-01-2006, 02:42 PM Thread Starter
How much modification its not a one piece it comes apart in 3 pieces
post #4 of 4 Old 01-01-2006, 03:03 PM
It depends on what kind of exhaust you're running. Even if you're running takeoff GT duals, you'd need to do some modification to get it to fit. What it comes down to is that if you're going for dual exhaust on a v6 anyway, might as well just fabricate (or have the shop fabricate) your own H-pipe.
Also, an H-pipe is unnecessary on the 3.8. Since the 3.8 has an even firing order, there is no need for a crossover to equalize pressure. I know it says that I have a custom H-pipe in my sig, but I did that before I realized it was unnecessary
