'86 rear end housing ? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 12-24-2005, 05:43 AM Thread Starter
Hi guys!
I'd like to swap my rear end with Strange 5-lug SN95 axles/c-clip/spool, SN95 brake parts.
Do I need to change the whole rear end housing and tube or the parts will bolt-in ? Is V6 3.8L diff. housing the same as GT V8 ?
1992 LX Coupe Deep Emerald Green
L4m4r is offline
post #2 of 5 Old 12-24-2005, 02:23 PM Thread Starter
forget it, I found the answer, will need to get rid of the 7.5" and change the whole thing so I'll try to find a 1994-1995 8.8 rear end!
But another question hehe:
Do my V6 driveshaft bolt to the 8.8 rear end ? Or maybe a V8 driveshaft slip int he V6 transmission ?
I want the car to be functional before I drop the engine and c4 transmission.
L4m4r is offline
post #3 of 5 Old 01-01-2006, 04:29 AM
I'm pretty sure the v6 driveshaft will bolt right in. In fact, I think the v6/v8 driveshafts are identical
Cougarstang is offline
post #4 of 5 Old 01-20-2006, 07:28 PM
351GT40's Avatar
the driveshafts bolt up the same, and you dont really need a housing from a 94-95 the 8.8 housings are the same from '87-'98 so you can swap 94-98 V6 rear brakes (axles and all brakes) right into any 87-98 8.8 housing
buying US silver coins pre-1965 *** '95 cobra #3787 5.8L ***
351GT40 is offline
post #5 of 5 Old 01-22-2006, 11:01 PM
Coupester's Avatar
Trader Feedback: (41)
You can also use 1986 8.8 Mustang housings, as those are also identical to 87-98 housings.
Chris
82 Mercury Capri - N/A AFR 165, FTI cam 11.99 @ 112
86 LX Coupe - Coyote, T56, 11.55 @ 121
Coupester is offline
