Port and Polish Intakes.... - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 12-04-2005, 02:59 PM Thread Starter
Ok so I may buy some p&p intakes from my uncle, however is it worth it. The cazr is a 02 V6 with cold air, 73mm MAF, and exhaust, rims, nothing else to motor. Does the intake require a colder thermastat? If so do I need to get the computer reprogrammed? thanks
J.
3.8ICEMAN is offline
post #2 of 5 Old 12-04-2005, 05:38 PM
mess with the therm, and you are asking for issues. THE computer WANTS the car at normal temp for a reason.
But honestly, I can't see what more air flow has anything do with the water temp.
faster? Hell, I just want to get it to start!
ramblemn is offline
post #3 of 5 Old 12-04-2005, 09:14 PM
you wont gain a ton of power maybe if ur lucky 10rwhp u gain alot from heads and a cam.intakes minamal.
you can run a 180 thermostat with no probs but unless u have ur fan reprogramed by the puter it wont come on till it hits the stock thermo temp range.u wont really see no gains on the thermostat anyways.
flamingpony is offline
post #4 of 5 Old 12-05-2005, 12:48 AM
Port and polish will make more of a differance if you run a sc or turbo.. otherwise not much.
Stan
V6Convertible is offline
post #5 of 5 Old 12-07-2005, 09:28 PM
99mustang232 is offline
