A leak in the back - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 08-29-2017, 07:35 AM Thread Starter
A leak in the back
My original 1983 V6 has a coolant leak that drips from the area about a foot in from the right about even with the rear of the front right tire. Hoses are dry and I can't see any evidence from above. I have two floor jacks but both are occupied so I took a dozen camera shots with the phone to see what I could find. The starter looks very wet. What is above in that area? Are there any freeze plugs that might be the cause? If so, how can I get access to them? There isn't much access between the back of the engine and the firewall? Are there any other possibilities for a leak back there? Does anyone have pictures of the back of this engine?
Thank you for any suggestions and info,
Justin
shrlsgrl is offline
post #2 of 3 Old 08-29-2017, 09:09 AM
IRUNEM2's Avatar
Trader Feedback: (170)
GET A BOTTLE OF COOLANT DYE ... ADD DYE DRIVE TO MIX DYE IN COOLING SYSTEM.
LET MOTOR COOL DOWN.. USE BLOW GUN TO AIR DRY.
PUSH CAR IN DRY AREA FOR TESTING.
USE COOLANT PRESSURE TESTER.
USE UV LIGHT/BLACK LIGHT TO FIND ORIGIN OF LEAK!
GOOD LUCK.
IRUNEM2 is offline
post #3 of 3 Old 08-29-2017, 09:15 AM
IRUNEM2's Avatar
GOOD LUCK.
IRUNEM2 is offline
ReInstalled 302, rocks front to back??? CypressLX 5.0/5.8 Engine Tech 2 07-02-2017 08:01 PM
Back in it again CCH New Member Introductions 1 01-18-2016 09:39 AM
Rear main vs tranny input seal leak Texasdoc 5.0/5.8 Engine Tech 6 03-21-2015 08:36 AM
Power steering leak Big Jay D 94/95 Tech 6 02-01-2012 03:29 PM
where could the leak come from/rear of engine Eleanor68 5.0/5.8 Engine Tech 6 02-14-2011 08:39 AM
