1995 3.8 Starting issue - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 07-24-2016, 07:06 PM Thread Starter
Reckful's Avatar
Hello and yes I am back.
I have been trying to trouble shoot this issue for the last couple of days and I have pretty much have gave up (For now).
-- Information --
My car broke down and would not start when I turned over the key. I have located several issues that have been resolved (New starter, CCRM, starter relay (Fuse Box), battery and even double checked all ground points and the issue is still playing.
Real Problem.
After replaced all parts within the area located about, there is still one that I haven't figured out. When I turn the key too the (on) position, my dashboard lights up like it's suppose too. However when I turn the key to engage the starter, the starter will engage twice and then I lose all power too the car until I reset the battery connections.
Once I have reset the connection, I get full power back to the car once more until I attempt to engage the starter again.
--My Resolution--
I was wondering if it is possible to put the starter on it's on isolated path with a external relay. I have asked around but no one seems to know the answer as most of the connections are tied into the fuse box.
If it is possible, how would I go about doing this without damaging or making something else mad
I'm sorry, if you were right, I'd agree with you.
Reckful is offline
post #2 of 3 Old 07-27-2016, 06:35 PM
indy2000's Avatar
how did you check grounds?
indy2000 is offline
post #3 of 3 Old 07-27-2016, 08:07 PM
scumbucket's Avatar
Yep. Grounds. Grounds. Grounds!
scumbucket is offline
1995 Cobra trouble starting when hot RedHorseman95Cobra 94/95 Tech 7 10-07-2015 12:23 AM
1995 Cobra trouble starting when hot RedHorseman95Cobra 5.0/5.8 Engine Tech 3 07-05-2015 09:51 AM
1992 lx starting issue blwn04vert 5.0/5.8 Engine Tech 14 06-23-2015 12:39 AM
1995 3.8 t-5 into foxbody 5.0 Mike Yorgey General Mustang Tech 3 01-02-2012 02:38 PM
1995 3.8 ? markedman90 Six Shooter 2 11-15-2011 04:24 PM
