1998 v6 - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 08-02-2015, 07:33 PM Thread Starter
1998 v6
Cab anyone explain to me why a 97 3.8 won't work in a 98? Trying to replace my son's engine but everyone is telling me it's a one year engine. Is there a way to swap some parts and make this work? Thanks in advance.
black00bolt is offline
post #2 of 3 Old 08-06-2015, 10:31 PM
To the best of my knowledge, they're the same. The difference came in 2000, where they went from external balance to internal balance in 2001. I am not 100% positive of the actual dates of the changeover, so you may want to research it before buying an engine. Also right around 2001, they went to IMRC (intake manifold runner control) which used a completely different upper and lower intake, different cylinder heads, and different ECU and wiring. Same short block as the 6 port 3.8's but thats' where the similarity ended.
I am about 75% sure that the change from external balance to internal balance happened in mid 2000. Meaning, late 2000 models had internal balance and early 2000 and prior were all external.
Ironic that you mention replacing an engine. I've got an 04 with a 3.9 and considering finding a good JY engine. Mine runs good but it vibrates and its getting worse. At 315,000 miles it's probably getting close to time anyway.
'92GT, 427" and '93 "LXVO" coupe
toddturbo is offline
post #3 of 3 Old 08-09-2015, 12:32 AM
badbrad's Avatar
Trader Feedback: (36)
94-98 basically the same....99 went to split port engines and returnless fuel system that's about it
New project: 86 Coupe
9 previous Mustangs--all gone
badbrad is offline
For Sale 1998 Ford Mustang GT 4.6L Manual Transmission Low-Emission PCM ECU ECM CADreamin Electronics and Entertainment 1 09-06-2014 05:20 PM
For Sale GORGEOUS CUSTOM 1998 FORD MUSTANG GT V8 2 DOOR COUPE MANUAL 5 SPEED 98 christopheregbert Mustangs For Sale/Wanted, 1994-1998 1 08-07-2014 09:05 PM
For Sale 22,000 Mile 1998 Mustang SVT Cobra Coupe mike1174 Mustangs For Sale/Wanted, 1994-1998 0 06-17-2014 08:08 PM
For Sale 1998 LX Coupe W/ Cobra Swap, For Sale ORioLE Mustangs For Sale/Wanted, 1994-1998 15 12-08-2012 06:31 PM
