Headers keep glowing red - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 11 Old 01-22-2015, 05:59 PM Thread Starter
Anyone ever have a problem with there V6 headers keep glowing red?
79modfox is offline
post #2 of 11 Old 02-04-2015, 11:31 AM
cobraman1024's Avatar
Trader Feedback: (69)
That is usually a surefire sign of an intake source vacuum leak. Did you recently have work done to the top end of the engine? Intake to cylinder head gaskets or upper intake to lower intake gasket would be the place to start looking.
-1995 Cobra #182/4005; 305hp/ 300tq, 231k miles, Roush intake, export parts
-1996 Mystic Cobra #1666/2000; 351hp/309tq, 221k miles, built 284, H/C/I, ARH, Mezeire, LMAF, JLT, MM suspension
-1993 Mustang LX, 2.3L w/ T5 conversion, AJE/MM suspension w/ 8.8, 03 Cobra steering/brakes, 271k miles
cobraman1024 is offline
post #3 of 11 Old 02-21-2015, 07:40 AM Thread Starter
We have done a smoke test for Vac leaks and nothing shows up.
79modfox is offline
post #4 of 11 Old 02-21-2015, 09:55 AM
Tominator's Avatar
Running lean.....need to check O2 ratio...
Tominator is offline
post #5 of 11 Old 02-25-2015, 09:20 PM Thread Starter
Did that too and it's 14.5-1 tried making it richer and same thing
79modfox is offline
post #6 of 11 Old 03-09-2015, 06:09 PM
elarm1's Avatar
Screaming timing to me.
91 LX 306, AFR's, Vortech V3Si, Cobra brakes, MM Suspension goodies, Corbeau GTSII seats, 2014 Ford Gem Green Paint
https://lh5.googleusercontent.com/-RwTXmnJ1Q0k/U2vtRcPAdkI/AAAAAAAABfM/BvOY_n9hSW0/w583-h777-no/IMG_20140508_164620.jpg
elarm1 is offline
post #7 of 11 Old 03-23-2015, 09:58 PM
ITSAV6's Avatar
If the timing is too low the mixture can still be burning in the headers.
91 GT w/AOD w/red clutches,2800 Street Edge 9.5" lock up converter,Baumann shift kit, hooker equal shorties, BBK X,Flows, Ported E7's w/3 angle v-job. 9.30 in 1/8 w/2.73 gears and 2.1 60ft pedalling for traction!
ITSAV6 is offline
post #8 of 11 Old 03-23-2015, 11:23 PM
Decipha's Avatar
x3, glowing headers are due to being underadvanced, throw 20 degrees at it
decipha @ EFIDynoTuning
www.efidynotuning.com
Decipha is offline
post #9 of 11 Old 05-01-2015, 09:59 PM
S-Trimmed302's Avatar
Trader Feedback: (124)
I had this exact same thing happen to me on my coupe with 308" motor with t trim.I about pulled my hair out before I found the problem.My problem ended up being my idle air bypass valve.I swapped over to a new valve and the problem was instantly solved.My a/f was ALWAYS perfect but my headers still glowed red within 30 seconds of firing my car up..Temps were running 700-800* on each tube.
Double check your timing!! Too much advanced.timing OR timing that is too retarded will both cause the headers to glow red I have seen it first hand..!
My 92 Coupe- Under construction - Dart 347, TFS 205 11R heads,Custom Cam by Brian Friedentag "freezy74",TFS Box R Intake, 75mm Accufab TB, Hooker Supercomp 1 3/4" Full Lengths,Vortech Pass side YSI,8" Crank,2.85 blower pulley,Treadstone 1245-28 Intercooler,Snow Stage 2 Meth kit
S-Trimmed302 is offline
post #10 of 11 Old 05-03-2015, 11:10 AM
Trader Feedback: (41)
Not sure I've ever seen or heard the IAC causing such a condition... Glowing headers can be too lean or rich, timing be retarded too much or as mentioned previously, vac leak. Since you've done a smoke test for vac leak, then check your timing and verify fuel pressure under load.
Are you still running the factory CAT?
Panoles1 is offline
post #11 of 11 Old 05-04-2015, 12:43 PM
I had never heard of an Idle air bypass valve causing this problem either thats the reason it was the LAST thing I had to replace to find out the reason my headers were glowing red but it 100% fixed the problem on my motor!
For Sale Headers and misc exhaust parts nasty 91 Exhaust Parts 25 06-25-2015 07:27 AM
Should I be worried about this? Headers were glowing red Future303 94/95 Tech 13 07-08-2014 06:27 PM
what headers for removing trans with the automatic and headers still on 99v6red GT & SOHC 9 12-30-2013 01:20 AM
For Sale Headers, and misc exhaust parts nasty 91 Exhaust Parts 20 12-17-2011 08:12 AM
For Sale Hooker Super Competition Ceramic-coated 1-3/4" Headers for 79-93 302 SLO 5-OH Exhaust Parts 5 07-13-2011 09:53 AM
