1997 v6 mustang (getting faster) - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 17 Old 01-27-2014, 05:48 PM Thread Starter
Im building up a v6 stang and its getting quicker im just wondering what more I can do to it to cut my times even more.any advice would be helpful.
Mods so far: comp cam and pushrods, cai, 19lb injectors, aode with shift kit, 8.8 diff with 4:10s.duel exhaust
le-fox is offline
post #2 of 17 Old 01-27-2014, 05:58 PM
Stang8u 909's Avatar
Trader Feedback: (23)
I would say I have a set of bbk headers I would sell you but there for 99-04 lol
Stang8u 909 is offline
post #3 of 17 Old 01-27-2014, 06:00 PM Thread Starter
Im gonna order long tubes tommorrow.whatvdo you think about a throttle body?
le-fox is offline
post #4 of 17 Old 01-27-2014, 06:01 PM
Not really a v6 guy but I'm sure it would help
post #5 of 17 Old 01-28-2014, 08:35 PM
Did the 1984, 1985 & 1986 Mustang w/3.8L V6 come w/a 5-spd? Or was the 4-spd the only available manual transmission w/that engine option?
'98 GT equipped w/Koni, Eibach, Cobra R rims w/Yokohama tires, Cobra brakes all around & 3.73 gears. Also a Boss330 4.6 Cobra block w/PI heads & stuff from Accufab, ARP, Centerforce, Comp Cams, Fidanza, K&N, Mahle, Manley & Borla exhaust w/Mac Pro Chamber thrown in for grins & giggles.
Geezer is offline
post #6 of 17 Old 01-31-2014, 10:49 PM
Caleb-M is offline
post #7 of 17 Old 02-01-2014, 05:46 PM
rbohm's Avatar
Originally Posted by Caleb-M View Post
beat me to it.
64 falcon
66 mustang
05 grand marquis
fordsix.com admin
rbohm is offline
post #8 of 17 Old 02-04-2014, 01:26 AM
SteedaGT97's Avatar
With a cam, unported Eaton M90, 5% o/d pulley, comp springs, 30lb injectors, front mount intercooler, and stock manifolds w/ o/r x-pipe my 95 V6 put 260rwhp/350rwtq thru the stock 7.5 rear end.
'97 Grabber Blue GT- Mark VIII 4V swap w/ '98 Cobra cams,S/R Cobra intake,ported heads, tubular k-member, and 70mm single turbo
'10 Sterling Grey V6 pony pkg (daily)
SteedaGT97 is offline
post #9 of 17 Old 02-19-2014, 07:26 PM
If your planing on keeping the car put a turbo from TMA on it or a blower, I run a Procharger on mine.
05 Mustang GT mods: tri-ax shifter, SCT tune, JBA long tubes
96 mustang 4.2L procharged v6 ¼ mile time [email protected]
38stang is offline
post #10 of 17 Old 02-19-2014, 08:03 PM
Thunderbird sc engin and supercharge!! cheap, a lot performance parts and the short bloc is good for at least 350whp!! I have a couple of parts for that...
mike bolduc is offline
post #11 of 17 Old 02-20-2014, 10:19 PM Thread Starter
I slapped on a bbk tb,pacesetters lt headers bbk ud pulleys.the car feels stronger now.im hoping to run into a z28 or a gt to see what the lil six can do
le-fox is offline
post #12 of 17 Old 02-25-2014, 11:53 PM
Long tube headers made the single biggest improvement to my car. But my car does not see the street it is trailered to the track. So its open headers at this piont. But I did have 3" pipes to race mufflers when I ran the car in sportsman class. Know I run pro so off with the exhaust. The cars best time was 11.96 @ 114. On the Dyno the car was making 330hp with 487lbs of torque that's with a 130 shoot of nitrous at the axle. That was with the T5 trans which I replaced with a C4 after I broke it the 4th time.lol The Dyno numbers went down a bit with the C4 but the Et is just about the same. Pm me if you want more info.
2007 Mustang ( wifes car)
2014 F150 ( daily driver )
1998 Mustang 11.53 114mph pro charged 3.8
1989 Mustang 10.82 124mph ( sons car )
scorpiocgg is offline
post #13 of 17 Old 02-26-2014, 12:20 AM
Remove....V6
Install.......any V-8 with a good set of heads.
Honestly.....if you want to go as fast as a Lear Jet, you don't start off with a Cessna 172 and try and make it faster.
If it were me, I'd stick a nice 75shot of nitrous on it and see how long it lasts. Then when it blows up, you have an excuse to put a real engine in it .
Charlie5280 is offline
post #14 of 17 Old 02-26-2014, 04:54 PM
I have been hitting my stock bottom end 3.8 with a 130 shot to the axle on the dyno know for fives years. Must be making at least a hundred passes a year and it is still going strong.
post #15 of 17 Old 03-03-2014, 05:43 PM Thread Starter
I would like some specs on that 3.8
le-fox is offline
post #16 of 17 Old 03-04-2014, 06:41 PM
Here is a list of what my car has
98 3.8 stock bottom end with 95000 miles on the speedo which has been discounted for the last 4 seasons
C&L mass air. 19lbs injectors 56 mm tbody single port intake the upper was cut and shortened heads ported and polished Crane cam from SSM long tube headers no exhaust Under drive pulleys AC delete. MSD dis 6 Gt fuel pump. NOS wet system fogger which on the Dyno added 130 hp SCT tuner. Was a t5 but just changed to a C4 with trans brake reverted valve body. 8.8 strange 35 spline axles with a spool 4/11 gears Upr upper and lower soilded control arm with anti roll bar. Lakewood shocks and struts let me know if you have any questions.
post #17 of 17 Old 03-04-2014, 07:02 PM Thread Starter
How much hp is it making.have you ran it on the quarter?what spring, lifter, pushrods are you using?
le-fox is offline
My Mustang Videos mike06tr Video 3 10-05-2011 03:00 PM
For Sale 1989 Mustang LX 5.0L FULLY BUILT/RESTORED/Custom Dash! BOSSGT Mustangs For Sale/Wanted, 1987-1993 1 05-29-2011 07:43 AM
