1994 3.8L-slow start - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 09-23-2013, 09:48 AM Thread Starter
I was told to post this here....
My 3.8L is running great, but engine cranks too much before firing up.
No codes present. Not sure what is going on here.
https://forums.corral.net/forums/gene...low-start.html
94 3.8 Vert AOD
95 3.8 Vert AOD
98 3.8 Vert AOD
qtownhb is offline
post #2 of 2 Old 09-24-2013, 03:12 PM
Fuel system? Filter, regulator or pump could be clogged/bad. Try the key trick where you put the key to on and off like 5-7 times to keep starting the pump and see how easy it is to start.
trampledunderfoot is offline
Fox Won't Start - No Crank, Any Advice? MT0911 5.0/5.8 Engine Tech 9 04-21-2013 03:56 PM
No spark no start.. ZanAridDad GT & SOHC 21 02-11-2013 09:30 PM
Trying to start my new engine, cranks really slow and starter to flywheel mesh sounds LarsD General Mustang Tech 2 09-14-2011 09:08 AM
Hunting Idle ONLY on First Start TrickVert 94/95 Tech 11 06-06-2011 09:29 AM
Slow Crank/No start... Is it my Ground cables or pos/neg Cables? Black_cobra_95 5.0/5.8 Engine Tech 7 11-19-2010 10:47 PM
