3.8L misfire - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 08-29-2013, 09:24 PM Thread Starter
3.8L misfire
I am at my end. I have a 1994 Mustang 3.8L Automatic.
Got a P30x code, which is cyl 2 misfire. I have done the following:
Replaced the coilpack, plugs and wires. Replace the #2 plug again just to be sure. Replaced the intake manifold gasket. Replaced the injector (with a used injector).
Compression test was good on #2. Spark good to the plug.
I would like to be able to test the injector and injector wiring to ensure that is not the problem.
(Also made a trip to the junk yard and got MAF, IAC, IAT and a couple other used parts, none made a difference)
PLEASE Help!!!
94 3.8 Vert AOD
95 3.8 Vert AOD
98 3.8 Vert AOD
qtownhb is offline
post #2 of 10 Old 08-29-2013, 09:53 PM
swetrid's Avatar
Does is miss? Head gaskets were a major problem and a recall on 3.8L engine back in the day.
Ex Ford tech for last 17 years! 2016 Triple Yellow California Special
swetrid is offline
post #3 of 10 Old 08-29-2013, 10:11 PM Thread Starter
Yes, it has a miss.
I did the compression test and it was ok. Thought that would rule out the head gasket
94 3.8 Vert AOD
95 3.8 Vert AOD
98 3.8 Vert AOD
qtownhb is offline
post #4 of 10 Old 08-29-2013, 10:24 PM
swetrid's Avatar
Dead cylinder or intermittent miss?
swetrid is offline
post #5 of 10 Old 08-29-2013, 11:54 PM Thread Starter
#2 is dead. Nothing seems to be able to bring this one back from the dead
94 3.8 Vert AOD
95 3.8 Vert AOD
98 3.8 Vert AOD
qtownhb is offline
post #6 of 10 Old 08-29-2013, 11:57 PM Thread Starter
is there a way to test the injector and the wiring to it? Did the ohms test and it passed. Would like to see that the injector is good before tackling a head gasket
94 3.8 Vert AOD
95 3.8 Vert AOD
98 3.8 Vert AOD
qtownhb is offline
post #7 of 10 Old 08-30-2013, 10:41 AM
swetrid's Avatar
It could be valve train problem. I would remove the valve cover and inspect rocker arms and pushrods and valve springs .
swetrid is offline
post #8 of 10 Old 08-30-2013, 02:05 PM
Try doing a block check and a leak down test too, as far as the injector, they have a tool that checks pulsing while the engine is running just by placing the probe on the injector body, try even doing a cooling system pressure test
redkoa5 is offline
post #9 of 10 Old 08-31-2013, 12:13 PM Thread Starter
Problem Solved
I was able to measure the resistance in each of the injector circuits. The dead cyl had a resisitance on the positive side, which should not have been there. I replaced the PCM, problem solved.
Thanks to everyone for your suggestions and tips.
94 3.8 Vert AOD
95 3.8 Vert AOD
98 3.8 Vert AOD
qtownhb is offline
post #10 of 10 Old 09-03-2013, 03:41 PM
StalkerStang's Avatar
My old 94 V6 had an injector stick open. It was also the PCM. Seemed to be a common issue for that year.
90' LX________________2011 GT Premium, DD, manual
Previous 4 cyl.__________Brembo Package, Borla ATAK system
427W, in the works______JLT Intake, Tuned
StalkerStang is offline
Misfire at low RPM and when engine is under load sterry 5.0/5.8 Engine Tech 13 02-01-2016 08:53 AM
Carb 3.8L to EFI 3.8L swap 86caprirs Six Shooter 4 11-23-2015 08:44 PM
Junkyard Horsepower SUMMARY! slo5oh 5.0/5.8 Engine Tech 231 01-30-2015 11:35 PM
Small misfire question. bigcarfan GT & SOHC 2 11-05-2012 04:22 PM
