Suitable replacement for 3.8 valve springs? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 1 Old 07-14-2013, 06:33 AM Thread Starter
cgrant26's Avatar
Any reason these wouldn't work?
Outside Diameter of Outer Spring (in): 1.437 in.
Coil Bind Height (in): 1.125 in.
Damper Spring Included: Yes
Inner spring included: Yes
Spring Rate (lbs/in): 300 lbs./in.
Inside Diameter of Inner Spring (in): .760 in.
Seat pressure (closed): 135 @ 1.750
Seat pressure (open): 285 @ 1.250
Valve Spring Style: Standard
Max lift: .625
http://www.summitracing.com/parts/hrs-98432
http://www.summitracing.com/parts/hrs-97118
Going by the specs on the Comp springs for the ford 3.8, these are .127 wider on the OD than the stock springs which I believe will fit into the spring seat cups just fine. I'm using FRPP aluminum roller rockers (1.7/1) and it looks like the retainers will clear them. Obviously, they are not beehive style springs. I'm also running a 210/218 cam with .58" lift at 1.7/1 ratio so these should never even come close to coil bind.
Specs on the Comp springs for comparison: (from here)
Part # 26918
O.D. 1.075 1.310
I.D. .650 .885
Seat Load 125 @ 1.800
Open Load 367 @ 1.150
Coil Bind 1.100
Rate (Lbs./In.) 372
Titanium Retainer 762, 772, 788
Steel Retainer 761, 774, 783, 787, 795
Cup Seat 4705
Shims 4753
cgrant26 is offline
What Valve springs? Woody? Ed Curtis? Valve float!!!!! 1988Mustang5.0 5.0/5.8 Engine Tech 16 06-25-2013 09:00 AM
For Sale Comp Cams F4.6S XD262AH cams & 26113 valve springs foastic Modular Engine Parts 7 03-14-2012 08:39 PM
For Sale AFR Valve Springs cliffs302 Windsor Engine Parts 10 12-11-2011 08:50 PM
For Sale stock 05 3v heads, New comp cams valve springs, of road x pipes probercr93 S197 and Coyote Parts 0 07-11-2011 07:15 PM
Need HELP!!! If I am using Chevy Valves in 289 Heads, Do I need Chevy Valve Springs? Bughracing 5.0/5.8 Engine Tech 1 11-29-2001 05:12 PM
