3.8 problems - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 06-24-2013, 03:40 PM Thread Starter
3.8 problems
So I bought my wife a 2001 ford mustang v6 auto. Shortly afterwards I ran a can of seafoam through it and the fuel pump and filter messed up. We had a mechanic repace it and then had to fix the clip that connects the fuel pressure sensor in. Well it has run bad ever since.
At first start it misses bad for a few sec then lines out. when you throttle on it it stumbles then goes. Its had codes ever since we had to replace the fuel pump. One of the codes is p0420 the other is a bad speed sensor on the right wheel. It also is throwing the evap code and the check gas cap. I replaced the gas cap. I hate to just throw money at this thing.
dunning3075 is offline
post #2 of 3 Old 06-26-2013, 07:58 PM
With the p0420 check the code but i think thats an O2 sensor..have code read and see which one. Also look at the wires on the O2 sensors...loose or melted wires as well.
With the evap code is the vent properly on the gas tank?
warthogdriver is offline
post #3 of 3 Old 09-20-2013, 11:06 PM
badbrad's Avatar
Trader Feedback: (36)
My 2001 is throwing a code po420 too...gonna gut the cats..
New project: 86 Coupe
9 previous Mustangs--all gone
badbrad is offline
3.8 bell, 5.0 engine, and one unhappy starter... help please! ced715 94/95 Tech 8 05-21-2016 01:52 PM
Off road h-pipe from 94-98 3.8 on an 86 with 3.8 mleega1 General Mustang Tech 0 08-22-2012 05:36 PM
3.8 Question. What years are a direct bolt in for a '98 Stang? 90PandE General Mustang Tech 9 01-19-2012 03:31 PM
3.8 to 4.6 swap ???? 95stalker GT & SOHC 6 05-17-2010 12:17 PM
Problems w/ 1994 3.8 V6 Talisian General Mustang Tech 4 11-14-2002 12:11 PM
