V-6 Swap Question... - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 05-04-2012, 02:07 PM Thread Starter
i have a '95 mustang with a locked up 3.8. i also have a good '01 3.8 engine. my question is.......can i use the intake manifold and the exhaust headers off of the '95 on the '01 engine? i don't want to mess with the IMRC conversion...
TurboCoupeGuy is offline
post #2 of 3 Old 05-05-2012, 02:52 PM Thread Starter
nevermind. i see the heads are different.
post #3 of 3 Old 05-16-2012, 05:59 PM Thread Starter
okay....i just completed the split port swap. i'm using the '95 headers, wiring harness(modified), injectors, MAS, PCM, oil pressure sending unit and cam position sensor. the rest of the engine is 2001. it idles nice and steady at 550rpm but has a slight hesitation just off idle and CE light is lit. other than the hesitation, it runs fine. code is PO340, cam position sensor. i am pretty sure i have it installed correctly at 26 degrees ATC. it's hard to find exact TDC on these engines assembled. there is no mark on the front cover.
how much tolerance is there before it throws a code? i have room to move the CPS a couple degrees either way but i have no way of knowing if i "hit it" unless i keep clearing the code after i move it and see if it shows up again. nor do i know which way to go...
any suggestions?
another 2003 cobra rack swap question? fastcobra88 General Mustang Tech 2 02-17-2011 09:03 PM
Question about 351 swap headers superirish 5.0/5.8 Engine Tech 2 12-27-2001 07:11 PM
Quick question after motor swap. 95stang50 94/95 Tech 2 12-26-2001 11:15 AM
Aluminum Quad swap question wldtang 5.0/5.8 Engine Tech 0 12-23-2001 06:09 PM
One question about live axle swap?? BlackDemonGT GT & SOHC 14 12-19-2001 04:40 PM
