Engine Vibration - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 08-19-2011, 06:45 PM Thread Starter
onyxblue 97's Avatar
Engine Vibration
Hey Guys hoping you can help me ...I have a 2000 V6 (135,000 miles)
The engine is Vibrating a bit and it's particularly noticeable after 1000 RPM
I changed the Oil and it helped ...barely ... I looked at the Motor mounts
and they seem ok as far as I can tell anyhow... the transmission mount how ever
is shot!! How can I tell if in fact I need new motor mounts? Perhaps a
balancer?... if so how can I tell? The car has plenty of
power... but I am kinda at a loss..
Should I just replace the tranny mount?
onyxblue 97 is offline
post #2 of 4 Old 09-04-2011, 11:45 PM
how are the u joints? the motor mounts, put in gear with hood open, see if engine moves(you may need a buddys help). or try to rock it by hand. the tranny mount, loosen it up and jack the trans up. try to slip it out.
rusty7983 is offline
post #3 of 4 Old 09-04-2011, 11:47 PM
my 99 v6 has bad u joints. it vibrates. it is worse over 55- 60 mph. i got under and grabbed the driveshaft and shook it. it moved.
post #4 of 4 Old 10-04-2011, 06:52 PM
I work in a body shop and we had a car that had a vibration issue, finally figured out it was the tranny mount was tweaked and making metal to metal contact. If yours are shot, I would start there.
TROJANII is offline
Bad engine vibration after clutch, tran. change gt942nv00 94/95 Tech 22 09-27-2013 07:05 AM
Bad Engine Vibration while sitting still cobracoupe5 5.0/5.8 Engine Tech 13 08-22-2011 10:43 PM
engine vibration brettlanpher 94/95 Tech 0 04-21-2011 10:35 AM
engine vibration around 3500 RPM qwikstang92 5.0/5.8 Engine Tech 5 01-07-2002 09:48 PM
