2007 mustang v6 engines dies on a hot day - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 08-03-2011, 06:22 PM Thread Starter
i have a 07 mustang v6 on a hot day with the air running the car will die when coming toa stop taken it to the dealership and they cant find the probelm its done it every summer last year it didnt act up and now this year it acted up and dealership wont work on it cause warranty gone anyideas would help
blown1986 is offline
post #2 of 4 Old 08-13-2011, 11:46 PM
Green_6er's Avatar
fuel atomization sucks during the summer and cars don't run near as good than if it was cold and having the a/c on puts just a little bit too much drag on the engine and causes it too die. when coming to a stop turn the a/c off and see if it still does it.
Green_6er is offline
post #3 of 4 Old 08-15-2011, 04:10 PM
You could check the TPS (throttle position sensor) and the IAC (idle air control valve) as both give feedback on the idle situation. Check for codes with a scanner as well.
You may be able to set the idle (so to speak) by disconnecting your battery and leaving it for a while (say 10 minutes or so). When you reconnect your battery, start the car and turn every accessory on (light, signals, max AC, radio, step on the brake, and turn your steering wheel. This gives the computer an idea of where it should set the idle to keep you running at a stop light.
Good luck.
sperold is offline
post #4 of 4 Old 08-22-2011, 12:19 PM
onyxblue 97's Avatar
CHeck your codes........when was the last time you had a tune up?...
is your fuel filter as old as the car?
onyxblue 97 is offline
Mustang dies when hot SVTCobraLTD 5.0/5.8 Engine Tech 20 06-05-2015 01:38 AM
4.6 DOHC question. Rfreeman37 SVT & DOHC 313 01-07-2014 10:35 PM
For Sale Misc fox body parts n8secstangg Miscellaneous Mustang Parts 12 02-24-2013 12:29 AM
