1996 3.8l Camshaft synchronizer help - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 06-16-2011, 11:43 PM Thread Starter
i just helped a friend swap a 3.8l engine in his car and now i cant get it to run good. It seems to be a timing issue . I have the sychronizer tool but did not get to mark the original location . I have tried moving it a couple of teeth both ways and has not helped. The car has a build date in the door of 7-95.. So does that mean its setup for the 95 or 96 sychronizer installation . there seems to be more thenn one procedure for timing a 3.8l ...FML Any help would be appreciated
tnhotrod is offline
post #2 of 4 Old 06-17-2011, 10:27 PM
jamesklyne's Avatar
Try v6power.net. BTW if you swapped the engine why would the timing be off in the first place? I'm guessing it's not a junkyard motor but a rebuild?
1999 Firebird turbo
1995 Mustang GTS
jamesklyne is offline
post #3 of 4 Old 06-18-2011, 04:02 PM Thread Starter
3.8l
Replacement engine came without timing cover..
tnhotrod is offline
post #4 of 4 Old 06-30-2011, 06:26 PM
#1 at tdc of "compression stroke"
herbiehind is offline
Junkyard Horsepower SUMMARY! slo5oh 5.0/5.8 Engine Tech 231 01-30-2015 11:35 PM
For Sale 1996 Mustang Dash Wire Harness (NEW Ford) LX 5.0 Electronics and Entertainment 0 05-11-2011 10:10 AM
Thinking about converting my SVO 2.3L to SC 3.8L, anyone done this? phils97gt General Mustang Tech 5 04-24-2011 11:59 PM
is the 66969BK HEI distributor Compatible with my Edelbrock 2221 camshaft? danyj 5.0/5.8 Engine Tech 2 12-13-2010 11:32 AM
Using Hyd. Flat-Tappet Lifters on a Solid Camshaft? And Comp cam 35-609-5 question Bughracing 5.0/5.8 Engine Tech 8 12-09-2001 03:24 PM
